Browse Forums Building A New House Re: Building with Metricon 2962Apr 30, 2016 11:14 pm Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: Building with Metricon 2965May 01, 2016 9:46 am Second Build, this time with Carlisle 2016, can't wait! Beckham: viewtopic.php?f=31&t=67280 Canterbury: viewtopic.php?f=31&t=81175 Building with Metricon 2967May 02, 2016 9:08 pm Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: Building with Metricon 2968May 03, 2016 10:00 am Very urgent response needed - for those of you with an island bench in stone longer than 3m, where did you put the join? Can I put it through the middle of the sink which is an undermount sink or will this weaken the sink cutout? I'm seeing different answers from different people. Caesarstone told me to speak to the stone mason but I don't know who Metricon is using. Would love some guidance, thanks so much http://jazzyandluke.blogspot.com.au Building Metricon Glendale 38 http://jazzyandluke.blogspot.com.au Re: Building with Metricon 2969May 03, 2016 11:55 am jazz_d Very urgent response needed - for those of you with an island bench in stone longer than 3m, where did you put the join? Can I put it through the middle of the sink which is an undermount sink or will this weaken the sink cutout? I'm seeing different answers from different people. Caesarstone told me to speak to the stone mason but I don't know who Metricon is using. Would love some guidance, thanks so much http://jazzyandluke.blogspot.com.au Personally , I prefer a joint in the middle (if it has to be a joint) Re: Building with Metricon 2970May 03, 2016 10:38 pm Hi Jazz, In the display home its closest to the end facing the dining. I wouldn't want it right down the middle myself as I had it in my previous house, that's why we went 3 metres only! My Metricon Glendale in Sydney. Re: Building with Metricon 2971May 04, 2016 9:49 am HGMbuild Hi Jazz, In the display home its closest to the end facing the dining. I wouldn't want it right down the middle myself as I had it in my previous house, that's why we went 3 metres only! yes , if it was me , I will keep the island under 3M to avoid joint Re: Building with Metricon 2972May 04, 2016 8:10 pm Has anyone had to upgrade their insulation for energy rating requirements? The price from our initial quote has increased nearly 100% when compared to the price given at our P/E appointment. Our SC's explanation is confusing, particularly with regards to how they calculate the insulation costs for internal walls. Any assistance/input would be appreciated. Re: Building with Metricon 2973May 04, 2016 8:37 pm We insulated 3 internal walls at a cost of $450, that is all i have to offer on that sorry bpglendale! This is why i HATE their estimating, it is too far out with some things. We had a few things double in price at prelim contract time from what was initially quoted and i kicked up a stink and said that I would understand a bit of a higher price, e.g garage was quoted at $3k but came back at $3150 which i said was fine. However the driveway size increase doubled and the alfresco extension/reduction of rumpus price came back about $1k more and they credited both of those increases back so that it was as per original quote! Re: Building with Metricon 2974May 05, 2016 7:20 am kylz4 We insulated 3 internal walls at a cost of $450, that is all i have to offer on that sorry bpglendale! This is why i HATE their estimating, it is too far out with some things. We had a few things double in price at prelim contract time from what was initially quoted and i kicked up a stink and said that I would understand a bit of a higher price, e.g garage was quoted at $3k but came back at $3150 which i said was fine. However the driveway size increase doubled and the alfresco extension/reduction of rumpus price came back about $1k more and they credited both of those increases back so that it was as per original quote! The estate that we're building in stipulate a 7-star energy rating for encumbrance approval. Our total insulation upgrades have increased from about $2.5 k to just under $5k, and the explanation is because they used Melb specs instead of Adelaide. Apparently there was also an error with the estimating system which will now be rectified for future quotes. Strange this is the first time it's ever been queried by anyone?? Re: Building with Metricon 2975May 05, 2016 9:16 am Hi I have an issue with main bathroom commode's water leaks and don't know where it starts. I need your advice abut this. Is it issue with ceramic commode or poor plumbing? I don't want M to put any water proof sealed as it 2 months old and want them to replace ceramic commode/tiles and redone everything from the beginning. Pls advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: Building with Metricon 2976May 05, 2016 2:18 pm Mel sydney Hi I have an issue with main bathroom commode's water leaks and don't know where it starts. I need your advice abut this. Is it issue with ceramic commode or poor plumbing? I don't want M to put any water proof sealed as it 2 months old and want them to replace ceramic commode/tiles and redone everything from the beginning. Pls advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks I think the commode itself has a leak at the bottom where it joins the floor. Anyway that's how it looks from the photo. They may need to reset the commode and silicone it again. Is there any sign of water damage on the wall or behind the wall the commode sits on (check the along the skirting board). If the commode is upstairs check the ceiling on the ground floor right below the commode. If there is no water damage it is unlikely there is any plumbing issue. I won't be asking M to redo everything until you get it assessed. Worse case they may need to put in a new commode. It's not unusual when we renovated our bathroom our bath tub and commode leaked, the plumber came back and re fitted and we have not had any issues. Include it in your 90day warranty. Good luck viewtopic.php?t=78985 Re: Building with Metricon 2977May 05, 2016 2:58 pm Franky40 Mel sydney Hi I have an issue with main bathroom commode's water leaks and don't know where it starts. I need your advice abut this. Is it issue with ceramic commode or poor plumbing? I don't want M to put any water proof sealed as it 2 months old and want them to replace ceramic commode/tiles and redone everything from the beginning. Pls advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks I think the commode itself has a leak at the bottom where it joins the floor. Anyway that's how it looks from the photo. They may need to reset the commode and silicone it again. Is there any sign of water damage on the wall or behind the wall the commode sits on (check the along the skirting board). If the commode is upstairs check the ceiling on the ground floor right below the commode. If there is no water damage it is unlikely there is any plumbing issue. I won't be asking M to redo everything until you get it assessed. Worse case they may need to put in a new commode. It's not unusual when we renovated our bathroom our bath tub and commode leaked, the plumber came back and re fitted and we have not had any issues. Include it in your 90day warranty. Good luck viewtopic.php?t=78985 Thanks Franky. I m still angry with M works. Not only this. it almost 2 months now and still pending items. Yesterday another issue fixed with drilling more hole in WC. I m thinking put feedback on M productareview site with 0 stars. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Metricon 2978May 05, 2016 8:24 pm Ok, kind of building related. Jetstar have flights on sale at the moment and i would LOVE to do a little family holiday but it will be during the build. Do you think it would be ok to not be able to check up on everything for a few weeks??? Re: Building with Metricon 2979May 05, 2016 8:30 pm kylz4 Ok, kind of building related. Jetstar have flights on sale at the moment and i would LOVE to do a little family holiday but it will be during the build. Do you think it would be ok to not be able to check up on everything for a few weeks??? A few weeks should be a problem as the works generally stop and start. Unless the holiday happens to fall on the time when a stage is complete and you need to inspect or instruct the bank to make payment. Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 2980May 05, 2016 8:47 pm We are just about to go away for 3 weeks and I will admit it's the worst timing, when we booked it we didn't know if they would have even started building and assumed that it would be fine - I was over at the site today because the electrician needed me to clarify where things needed to go. I didn't think we would be as involved as we are. Also, our site manager has asked if he can reach us by phone/email if he needs to. If I could go back I would have saved the holiday for after the build is finished - too stressful lol!! Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10749 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17331 |
