May 21, 2013 5:26 pmSign In54 members logged in
Building Forum » Building, Renovation & Maintenance » Kitchen Corner
Frosted Perspex splashback
New Topic Post Reply  Page 1 of 1
 [ 10 posts ]
Mel_jade
 Post subject: Frosted Perspex splashback
PostPosted: Oct 17, 2007 9:43 pm
Junior Member
Junior Member
Hi all,
I read somewhere that a cheaper alternative to a glass splashback is using frosted Perspex. Sounds like a great idea - the colour is quite similar to glass and it definately is cheaper. But I'm concerned about it's level of heat resistance.
Has anyone had any experience with using Perspex as a splashback?
Your thoughts?
Cheers,
Mel_jade
**Phoenix**
 Post subject:
PostPosted: Oct 17, 2007 9:51 pm
Hi mel_jade, i have used frosted perspex before but not as a splashback. They are not too expensive and come in a variety of thicknesses.
Try this place:
http://www.acryform.com.au/index.php?option=com_content&task=view&id=17&Itemid=41
They have reps all over.
Looks just as good in my opinion, but again not sure on the heat resistance.
Let us know how you go with it.
mattwalker
 Post subject:
PostPosted: Oct 17, 2007 10:01 pm
Support Team
Support Team
Whilst travelling this week I came across a little hole in the wall shop in Port Melbourne who cuts glass splashbacks to size cheap.
The place was in Crockford Street (continuation of City road) and was a bright blue building.
I spoke with a building mate and he had used him several times before and was generally less than 2/3rds of the cheapest quote he got.
Worth a look if you get a chance maybe.
Australia wide Local Call - 1300 85 4441
Click here to look around: http://www.thecableconnection.com.au
Casa2
 Post subject:
PostPosted: Oct 17, 2007 10:15 pm
With perspex my concern would not be heat resistance, but rather scratching.
Demolition August 2009, Construction Started September 2009, Completed December 2010
Strumer
 Post subject:
PostPosted: Oct 18, 2007 6:15 am
The only area where a splashback needs to be heat resistant is behind the cooktop.
Acrylic (of which Perspex is a brand) does not comply with the standards required of Fire Retardant Material suitable for use behind a cooktop.
As Casa also pointed out it is also more prone to scratching than glass - although with a frosted fisnish against a wall this will only be visible where the light refelcts off the damaged finish.
Cheers,
Earl
Struming Design - Industrial Design
Kitchen Design; Kitchen Supply; DIY Kitchens
Yak_Chat
 Post subject:
PostPosted: Oct 18, 2007 8:49 am
Speaking of splashbacks Strummer.
Have you ever supplied removable splashbacks?
I'm thinking how it's such a pain to clean the vertical surface behind the stove, if it was removable and could be popped into the sink / dishwasher it would be so much easier.
Any health issues you can think of that would stop it.
Stainless is the obvious choice with an overlaping lip on the edges and it pops into a retaining tab at bench level.
Steve
Strumer
 Post subject:
PostPosted: Oct 18, 2007 9:29 am
Interesting idea Steve.
Suprisingly there aren't really any standards or guidelines that need to be conformed to healthwise in this area.
I haven't had anyone ask for this sort of thing before but I think it is a fundamentally sound concept.
I could definitely design something that would answer that brief.
Keeping it healthy would mean focussing on the the sealing of the splash with the wall it is hanging on and the surrounding areas if it is to fit into a recess or butt up against any other surfaces.
I agree that stainless would be the easiest to work with - I would also be looking at a sheet with folded edges where the main surface sits proud of the wall behind it and the folded edges bevel back to meet the wall on an angle.
The sheet could hang on some slide in fittings which pull the sheet towards the wall as it locates - a sealing membrane/gasket behind the bevelled edge would provide the requisite water proofing.
I like stainless in kitchens a lot - my ideal kitchen would feature a significant amount of stainless; and a high pressure hose to clean the whole room out with....sort of a big walk in dishwasher concept...
Cheers,
Earl
Yak_Chat
 Post subject:
PostPosted: Oct 18, 2007 11:07 am
The idea came to me as I used to own a cafe on weekends and well you know what making your own soup from fresh vegies and then cleaning a commercial stove can be like :shock:
8 hours cooking - 4 hours cleaning :)
Yes a hose out kitchen is nice - but in the house - well maybe a tad messy :)
I was thinking of a slot similar to a sliding window that the steel or glass for that matter slips up under, which also creates a flap that stops splashes getting behind it.
On the cupboard level - I would leave it sealed and totaly waterproof to the wall - and if using steel - it would then be easy to locate a knobbed pin in the bottom edge of the wall (so the folded up 3 to 5 cm on the steel with a slotted hole cut in it can locate onto a pin out of the wall.
Steve
renomart
 Post subject:
PostPosted: Oct 19, 2007 11:52 am
Many cleaning products would have solvents that would mar the face of the perspex.
Mel_jade
 Post subject:
PostPosted: Oct 19, 2007 11:08 pm
Junior Member
Junior Member
Hmm...
Your comments have all been very helpful. I didn't think about the cleaning products problem. I guess it's probably not worth taking the risk - particularly because of the heat behind the cooktop.
Thanks Matt - will check out the glass guy in Port Melbourne.
Spent most of my budget on my beautiful Caesarstone benchtop so any tips to save money elsewhere are much appreciated!
 [ 10 posts ]
Users browsing this forum: CuttingEdgeKitchens and 15 guests
May 2013 Specials
2 x Espresso Table Lamps9 days leftBy Go Lights NSW
These stunning Espresso table lamps from Cafe Lighting are perfect for the bedroom or the living room. 2 of these lamps for less than $40...read more
10% off for the whole of MAY10 days leftBy SQUAREpeg - Moving Specialists VIC
Since you have the huge decision of choosing who to move with we feel it will make your life easier if we give you 10%...read more
Free Gift for all Homeone Customers10 days leftBy The Round Bath Company WA
Purchase any of our Spas from our huge range on Ebay this month, mention HOMEONE and receive a free gift with your first purchase. To...read more
Winter Rug Clearance Catalogue 16 days leftBy Harvey Norman The Carpet and Flooring Specialists ACT
Save, save, save with modern rugs, traditional rugs, shaggy rugs, wool rugs acrylic rugs and polypropylene rugs! There are many colours and designs to choose...read more
10% off 23 days leftBy PR Painting QLD
Receive up to 105 off your next Brisbane painting quote when you mention this advert...read more
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Read Article: LEDs - what you didnLEDs - what you didn't know!
You know how hot incandescent bulbs become. That's because they convert…
Read Article: Is your home Conducive to Termites? What to look for.. by Victorian House Inspections VICIs your home Conducive to Termites? What to look for..
Termites can cost you thousands of dollars in repairs and heartache.…
Read Article: AustraliaAustralia's Only Custom Hydrotherapy Spabath Systems
Roundbathcompany is proud to offer a Total product range of hydrotherapy…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
Watch Video: SlimWall Designer Fences Installation Video by SlimWall Designer Fences VICSlimWall Designer Fences Installation Video
SlimWall Designer Fences are the popular panel fencing innovation that combines…
