Browse Forums Outdoor Living Re: How to fix overflowing gutter with new Pergola 2Feb 26, 2013 10:37 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 4Feb 26, 2013 11:41 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to fix overflowing gutter with new Pergola 5Feb 26, 2013 2:34 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 7Feb 27, 2013 12:13 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 9Feb 27, 2013 7:00 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How to fix overflowing gutter with new Pergola 10Feb 27, 2013 9:00 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 12Feb 27, 2013 9:48 am I would need to measure the house but to give you an idea in that photo the mid point of the house would be around just to the left of the door as you look at the photo, so the downpipe pictured covers the whole area of the pergola, and the other downpipe covers an equivalent area of roof not shown in the photo. So in a nutshell the Pergola covers roughly 40% of the length of the house. I like the idea of the product you showed me, this could hopefully be the answer I am looking for. Either that or install a conventional downpipe. Also I entertained the idea of installing a rainwater tank under the deck some time back when we had strict water restrictions in place, but lost interest when the restrictions were relaxed. I am thinking to do this again now as I can use this downpipe to divert into the tank. Re: How to fix overflowing gutter with new Pergola 13Feb 27, 2013 9:50 am B STAR Is it possible that the rain is being pushed through the sheets and under the flushing?? Nick where do you have issues with water coming through? Is it in the middle or the whole way. Sorry if you have already answered this. The water is leaking through between a small gap between the gutter and the fascia ~1mm. SO in heavy rain I get water streaming onto the deck. I also have noticed some water staining on the eaves which brought me to realise that water was getting into the roof cavity. Re: How to fix overflowing gutter with new Pergola 14Feb 27, 2013 11:14 am Nick82 the mid point of the house would be around just to the left of the door as you look at the photo This means that you could possibly fit something to the left of the pergola. Unfortunately, I cannot see that side but another drain doesn't necessarily have to be close to the middle as there is no high point. Overflows also often appear larger in volume than they actually are as they come over in sheet form. Nick82 I like the idea of the product you showed me, this could hopefully be the answer I am looking for. Either that or install a conventional downpipe. A plumber would probably charge $400+ to install a new downpipe, change another downpipe to a 90mm round and then connect the two downpipes unless A.C.T. plumbers work at cheap rates. You could fit the other product yourself and it would cost about $20. You can also divert that water to a tank. Nick82 Also I entertained the idea of installing a rainwater tank under the deck some time back when we had strict water restrictions in place, but lost interest when the restrictions were relaxed. I am thinking to do this again now as I can use this downpipe to divert into the tank. I can't see the available space under the deck but going by the lay of the background fence, there doesn't appear to be a lot of room. Were you considering bladder tanks? Bladder tanks are expensive and the water quality needs to be good unless there is a quick turnaround of the water stored. If you decide to do anything in this area, ask for advice in Eco Living. There is a lot of information to pass on that would save you heaps. I will PM some basics. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 15Feb 27, 2013 12:58 pm There is approx 1 metre in height under the deck, I investigated slim tanks that would fit at the time. I am thinking I will take you up on your offer using your product. Do you think that this will be successful and do you think it will work better than a standard downpipe? The problem with installing the downpipe to the left of the door is that there is a hot water unit between there and the downpipe at that end, and I would prefer to hide some of it under the deck. Also I think that locating it between the door and the window is closest to the problem and therefore will be the most effective. Re: How to fix overflowing gutter with new Pergola 16Feb 27, 2013 1:47 pm It is not a downpipe replacement, it supplements the downpipe during major rain events, only works during heavy rain and drains as fast as 3 garden taps. No point paying hundreds of dollars when you don't have to. Just PM a mailing address. EDIT: The product discussed was the Supa Gutter Pumper. https://gutterpumper.com.au/ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 17Mar 01, 2013 4:09 pm Hi Nick, If there is room to run the 20mm pipe down the wall to the left of the door, then this would be the best place to fit it. The greater roof area drains to this area of gutter and the device will pull water from both sides of the gutter. This will assist both downpipes. You should also look at running the pipe down the RHS side of that wall section as this should also allow you to drill a small hole (about 28mm diameter) through a decking board for the pipe. Access and fitting will also be much easier. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to fix overflowing gutter with new Pergola 19May 29, 2018 3:26 pm Nick82 Thanks for the tips, I plan to install it between the door and the window, as that is the most central location where it can be connected to the downpipe. Hi Nick, Just wondering if you have solve the problem? My old house has a similar problem and I am looking for solutions as well. Regards Tom Re: How to fix overflowing gutter with new Pergola 20Jun 04, 2018 1:37 pm Hi Tom, Yes I can happily say it has fixed the problem using a gutter pumper. However you need to regularly clean the inlet in the gutter as it clogs up with leaves easily which blocks the flow. If you also use some gutter guard then I would say this would fix it from blocking up. Is there a building permit? RU in Victoria? What is the value of the building contract? 1 6821 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4931 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8970 |
