Browse Forums What's New Use of Structural Insulated Panels 76Aug 17, 2012 12:01 pm chardy We built our 2 storey house here in the UK 4 years ago with SIPs for the walls and found them to be a great system. 2 of us assembled the whole shell including 1st floor joists and boarding in just 9 days with no prior experience. Our SIPs are OSB face both sides with a 100mm Polyeurethane core, any supportive beams are Glulam. Inside we battened out to create a cavity for cabling/plumbing before plasterboarding the whole lot. Outside has a membrane then battens supporting a brick tile cladding system so looks like brickwork but isn't ! We move over to Perth later this year and would love to self build (owner build) again using SIPs but most companies in Australia seem to only do EPS cores which I am not keen on and not as good as PU in my mind - anyone know different or shall I set up a factory myself ?? Justin Chris here (bensdad aka pio) we are using an r9 panel system in Perth to build with we also use afs as well. I'll pm you the details. PPA 30/6/12, Land 28/06/12, Contract 7/9/12, Valuation 11/9/12, Prestart 13/9/12, Settlement 18/10/12, Building Permit Issued 18/10/12, Footings 30/10/11, Slab 31/10/11 Re: Use of Structural Insulated Panels 78Aug 21, 2012 2:14 am Steel, We ran our cables behind the plasterboard which was battened out from the SIPs. I'm not a great fan of chases through the insulation ! Builda, Good to see a OSB-PU-OSB panel may come on the market, nothing but good reports from me after 5 years ! Chris, Nice one, look forward to seeing your build when I get there ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Use of Structural Insulated Panels 80Aug 25, 2012 6:36 pm 2 ways to do it here but it depends on local electrical regulations as to which is suitable. 1. A layer of plasterboard onto the SIP with gaps left for the cable drops then another continuous layer over the top - gives a more solid feel. 2. 25mm vertical roofing battens at 300mm centres and plasterboard over the top giving a nice clear cavity for the cabling. Hope this makes it clearer ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3524 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32540 |
