May 23, 2013 4:19 pmSign In60 members logged in
Building Forum » Building, Renovation & Maintenance » Windows & Doors
Which Way does the Low/E sheet go in a double glazed unit
New Topic Post Reply  Page 1 of 1
 [ 2 posts ]
Alan Cuthbertson
 Post subject: Which Way does the Low/E sheet go in a double glazed unit
PostPosted: Jul 12, 2012 8:18 pm
New Poster
New Poster
I am trying to undersatnd the use of Low/E glass in double glazed units. The WERS rating indicate a 25% reduction in the U value by using a Low/E sheet. My understanding is that the improved performance comes from the fact that it reflects heat in the long wavelength region back into the house.
The question is, which sheet should have the Low/E film? I know the low/E film should face the gap so it is protected, but should it be on the inside sheet or the outside sheet? My supplier says it should be on the outside because we are in a hot climate (Melbourne) but I am not so sure.
I have looked further at it, and it seems that the U value is not affected by the direction. The film reflects from the back just as well as from the front. What does change is the Solar Heat Gain. Effectively the Low/E film absorbs heat when sunlight falls directly on the window so the Low/E sheet will be warmer than the plain sheet. In winter you would like the warmer sheet on the inside of the unit, in summer you want it on the outside sheet.
My understanding is that in Europe the Low/E sheet goes on the inside to give better winter performance, but in Australia they put it on the outside to give better summer performance.
My feeling is that this is rather simplistic. If you are spending more on heating than cooling, you should put the Low/E sheet on the inside. Also, If your windows are protected from the sun in summer (e,g external blinds or eves) you should put the Low/E sheet on the inside.
Can anyone confirm whether my logic is basically correct and what others do in cold and warm climates?
ed @ ecoclassic
 Post subject: Re: Which Way does the Low/E sheet go in a double glazed uni
PostPosted: Jul 12, 2012 11:43 pm
Advertiser
Advertiser
Hi
The surface position on which the low-E glass will be placed is dependent on the climate. Ideally for warm climates where summer heat reduction is a priority, the coating should be on surface 2 for maximum performance (Note: the surface number is counted from the external surface of the outer pane [1], right through to the external surface of the inner pane [4]). The coating on surface 2 minimises heat gain because it reduces heat build up in the air gap and heat transfer to the interior.
But it works both ways, in both positions, just more effective in the positions mentioned. So really it should have two u-values, one for each location.
Ed
EcoClassic
Double Glazing in Aluminium & Thermally Broken Aluminium
Replacement Window Experts Including Installation (Melb)
http://www.ecoclassic.com.au
ed @ ecoclassic.com.au
Tel. 1800 326 326
 [ 2 posts ]
Users browsing this forum: No registered users and 6 guests
May 2013 Specials
2 x Espresso Table Lamps7 days leftBy Go Lights NSW
These stunning Espresso table lamps from Cafe Lighting are perfect for the bedroom or the living room. 2 of these lamps for less than $40...read more
10% off for the whole of MAY8 days leftBy SQUAREpeg - Moving Specialists VIC
Since you have the huge decision of choosing who to move with we feel it will make your life easier if we give you 10%...read more
Free Gift for all Homeone Customers8 days leftBy The Round Bath Company WA
Purchase any of our Spas from our huge range on Ebay this month, mention HOMEONE and receive a free gift with your first purchase. To...read more
Winter Rug Clearance Catalogue 14 days leftBy Harvey Norman The Carpet and Flooring Specialists ACT
Save, save, save with modern rugs, traditional rugs, shaggy rugs, wool rugs acrylic rugs and polypropylene rugs! There are many colours and designs to choose...read more
10% off 21 days leftBy PR Painting QLD
Receive up to 105 off your next Brisbane painting quote when you mention this advert...read more
Read Article: Modular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards by Modular Wall Systems VICModular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards
The industry leading supplier of stylish, cost-effective acoustic & boundary walls…
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Read Article: LEDs - what you didnLEDs - what you didn't know!
You know how hot incandescent bulbs become. That's because they convert…
Read Article: Is your home Conducive to Termites? What to look for.. by Victorian House Inspections VICIs your home Conducive to Termites? What to look for..
Termites can cost you thousands of dollars in repairs and heartache.…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
Watch Video: SlimWall Designer Fences Installation Video by SlimWall Designer Fences VICSlimWall Designer Fences Installation Video
SlimWall Designer Fences are the popular panel fencing innovation that combines…
