May 20, 2013 1:02 pmSign In51 members logged in
Find SuppliersPhotosVideosArticlesExpertsForumAdvertise
Building Forum » Outdoors » Landscape & Garden Design
Australia's greatest home building and renovation community providing you with access to the popular building forum, planning and budgeting tools, and the premium building directory.
How much concrete is JUST enough under pavers?
New Topic Post Reply  Page 1 of 1
 [ 14 posts ]
Lex
 Post subject: How much concrete is JUST enough under pavers?
PostPosted: May 17, 2012 5:35 pm
Need to investigate this solution.
We need the thinnest possible layer of concrete to go under some pavers. This will be strictly light foot traffic only, and it's a small area (maybe 3 m2 max).
Can we just put some builder's VB plastic, then some 4cm thick concrete layer, and then some 1cm sand and then the pavers? (or even just glue the pavers onto concrete) ??? Or is this still way too thin??
Any thoughts?
My signature is distracting people from my wise posts ...
bashworth
 Post subject: Re: How much concrete is JUST enough under pavers?
PostPosted: May 17, 2012 5:57 pm
100mm will be plenty Lex
Its probably easiest to lay the pavers on a thin sand layer ( I would tend to add 5% cement to the sand to stop it settling over time)
The harder you try - the luckier you get
Web site
http://www.anewhouse.com.au
Informative, Opinionated, and a little bit Cheeky - at least 3 posts a week on all aspects of building a new house.
Lex
PostPosted: May 17, 2012 10:32 pm
::hyst:: I was hoping less than half of that, like 40mm maybe :(
Would such thin concrete (40 mm or less) actually be useless (eg. would it crack quickly under the weight of pavers when walked on) ??
bashworth
PostPosted: May 18, 2012 5:54 am
You don't actually need any concrete. 100mm of well compacted road base will be as good. But make sure you use a compacting plate.
Web site
mgilla
PostPosted: May 18, 2012 8:05 am
Silver Member
Silver Member
Lex 40-50mm is more than enough. As long as you get a flat finish on it you just lay the pavers straight on top and then use a good tile glue to stick down the header coarse.
Once you have them layed mix some dry fine sand and cement, broom this over the top then hose off with low pressure while you broom it.
Lex
PostPosted: May 18, 2012 10:36 am
Thanks guys. :D
Well, what we want is to make the paving base (be it concrete or sand only) as much water proof as possible, but not really 100% a permanent soultion because this area runs over a miriad of shallow placed water tank and other pipes. And given our experience with anything to do with water-related installations, we figure that it's better to allow fairly easy access for repairs of the pipes in the future - therefore we did not concrete over this area in the first place, but it still needs to be covered with something fairly water proof because this is a very flat area where the house foundations are most at risk and there is no natural fall.
So we thought that a thin concrete bed would be OK as it would be more water proof and also easier to break up - need be in the future. And pavers on top of the concrete are not that hard to remove (and reuse later on).
Obviously, the easiest would be to just use sand under pavers, but we noticed that it allows most of rain to get and stay under the pavers, so it's not a good solution for this particular case.
BeatrixKiddo
PostPosted: May 18, 2012 12:35 pm
Your foundation could also move if there is no moisture in the soil and you have a reactive soil.. But you could still use a flexible system with a compacted sub base and sand but fill the paving joins with a flexible grout so if the pavers move the surface will still be water proof.
* jas *
PostPosted: May 18, 2012 3:09 pm
Bronze Member
Bronze Member
If your going to lay a concrete base it really should be reinforced and thick enough as once you go over the sand base with a plate compacter you might end up cracking the concrete base. Personally I would not bother with the concrete base.
Sent from my iPad using Tapatalk
Jasmin
Hickinbotham Belmont - modified
Signed: February 2011
Slab should go down before 2012
My build thread http://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483
Lex
PostPosted: May 18, 2012 8:04 pm
Thanks guys :D
Well, we suffer from too much moisture - ATM. But this could all change dramatically if it dries out well one day ... which just got me realise that excessive drying would probably not be that good for the slab :th: .
BK, did you mean to suggest one of those "Pavelock"-type products, instead of plain sand??
BeatrixKiddo
PostPosted: May 18, 2012 10:24 pm
Hey Lex,
No more like a silcon you would use on expansion joint. If you pave over a profile of crushed rock and sand on re active soils (clay) the pavers will move around. A solid join will crack and leak water through where a flexible joint wont.
bashworth
PostPosted: May 19, 2012 7:49 am
Lex wrote:
Thanks guys. :D
Here is a recomendation
    1. Excavate the existing material to a depth of 100mm+ the depth of the pavers leaving a slight (say 1:50 fall)
    2. Compact the soil with a vibrating plate ( any pavement is only as good as the base and the trenches for those pipes will mean that there will be areas of uncompacted soil)
    3. Lay the builders plastic.
    4. Lay a 100mm layer of cement stabilised sand (5% cement you can add it yourself as you barrow the sand in)
    5. Compact the sand and finsh to the required level not forgetting the slope.
    6. Leave overnight to harden
    7. Another sheet of plastic then lay the paver blocks
    8.Brush in the paverlock
Web site
Lex
PostPosted: May 19, 2012 8:53 am
That sounds good, Bash :D
We were also thinking of using the palstic (a lot!), plus then somehow seal the edges of plastic to house wall/slab. We also thought to somehow "incorporate" :wink: some rubber sheeting in that area, as we noticed that it withstands the sun and rain really well. Maybe even use rubber instead of plastic ?!
Just one thing - did you mean to just lay the pavers directly over that top layer of plastic, or do we still need some bedding sand on top of it (and directly under the pavers)?
BK, so what sealant / silicone are you thinking of? Yep, any rigid seal would quickly break.
bashworth
PostPosted: May 19, 2012 9:47 am
Black plastic is better than rubber for a long life.
Because of you concerns I would lay the pavers directly on the plastic. If you do this there is no need to use a flexible sealant between the pavers. as the amount of water in the joints between pavers will be negligible and quickly evaporate.
Brian
Web site
Lex
PostPosted: May 21, 2012 8:07 am
Makes sense! Thanks, Brian.
 [ 14 posts ]
Users browsing this forum: Cody Drysdale, Qqwe, Sir Snagger and 12 guests
homeone® - Australia's home building and renovation resource.
home building and renovation directory
May 2013 Specials
2 x Espresso Table Lamps10 days leftBy Go Lights NSW
These stunning Espresso table lamps from Cafe Lighting are perfect for the bedroom or the living room. 2 of these lamps for less than $40...read more
10% off for the whole of MAY11 days leftBy SQUAREpeg - Moving Specialists VIC
Since you have the huge decision of choosing who to move with we feel it will make your life easier if we give you 10%...read more
Free Gift for all Homeone Customers11 days leftBy The Round Bath Company WA
Purchase any of our Spas from our huge range on Ebay this month, mention HOMEONE and receive a free gift with your first purchase. To...read more
Winter Rug Clearance Catalogue 17 days leftBy Harvey Norman The Carpet and Flooring Specialists ACT
Save, save, save with modern rugs, traditional rugs, shaggy rugs, wool rugs acrylic rugs and polypropylene rugs! There are many colours and designs to choose...read more
10% off 24 days leftBy PR Painting QLD
Receive up to 105 off your next Brisbane painting quote when you mention this advert...read more
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Read Article: LEDs - what you didnLEDs - what you didn't know!
You know how hot incandescent bulbs become. That's because they convert…
Read Article: Is your home Conducive to Termites? What to look for.. by Victorian House Inspections VICIs your home Conducive to Termites? What to look for..
Termites can cost you thousands of dollars in repairs and heartache.…
Read Article: AustraliaAustralia's Only Custom Hydrotherapy Spabath Systems
Roundbathcompany is proud to offer a Total product range of hydrotherapy…
Watch Video: SlimWall Designer Fences Installation Video by SlimWall Designer Fences VICSlimWall Designer Fences Installation Video
SlimWall Designer Fences are the popular panel fencing innovation that combines…
Watch Video: Modular Wall Systems Factory Acoustic test by Modular Wall Systems VICModular Wall Systems Factory Acoustic test
See the acoustic results achieved from one of our BarrierWalls installed…
