Browse Forums Kitchen Corner Re: Above counter isolation switch for induction cooktop? 7Mar 06, 2012 9:42 pm kdgirl My parents got one in their new kitchen. It was put on the same plate as a plug switch so doesn't look out of place Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: Above counter isolation switch for induction cooktop? 9Mar 06, 2012 10:14 pm Hi Emery. My sparky said exactly the same thing. The current draw on the induction was too great for a switch that could be fitted to a standard GPO and had to be a separate switch. We were able to get the switch placed inside the appliance hutch which is next to the hotplates so you don't notice it. I'm very happy we didn't have to have it mounted on the glass splashback. He did comment that he could have just fitted a switch on a GPO however he wanted to do things as per code. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Above counter isolation switch for induction cooktop? 11Mar 13, 2012 10:59 am Your sparkie is either telling fibs, or you are using something other than the generic HPM or Clipsal switch plates. We did a kitchen reno about 12 months back including new appliances, and had to install the isolation switch for the electric oven. It's a 30amp switch as well. I went to John R Turks and got the 30amp switch and a double GPO with an extra switch in the middle. Pop the 10amp switch out, push the 30amp switch in, perfect fit. Double-checked with sparkie and a Council building inspector - both gave it the thumbs up. Re: Above counter isolation switch for induction cooktop? 12Mar 13, 2012 11:08 am We are having Induction cooktops in our build and have also been told the isolation switch must be separate. Luckily it can sit on the other side of the nib wall in the butlers pantry, so will be out of sight. Re: Above counter isolation switch for induction cooktop? 13Mar 13, 2012 5:23 pm Rogue It's a 30amp switch as well. I went to John R Turks and got the 30amp switch and a double GPO with an extra switch in the middle. Pop the 10amp switch out, push the 30amp switch in, perfect fit. Double-checked with sparkie and a Council building inspector - both gave it the thumbs up. I'll check and see if I can get a 32A switch for a Clipsal Slimline double GPO; my electrician's concern, which I confirmed with him yesterday, was the high draw when the normal switch is 10A. Re: Above counter isolation switch for induction cooktop? 14Mar 13, 2012 7:38 pm There is another thread in this forum regarding isolation switches - see this viewtopic.php?f=16&t=23265 I find the requirement for isolation switches just a bit confusing wrt to Induction cook tops when you consider this post from the above thread - Take a look at the wiring rules handbook at a library, AS/NZS 3000:2007, section 4.7.1 COOKING APPLIANCES Switching device states "A circuit for fixed or stationary cooking appliance having an open cooking surface incorporating electric heating elements, e.g cooktop, deep fat fryer, barbecue griddle or similar, shall be provided with a switch, operating in all active conductors, mounted near the appliance in a visible and readily accessible position." Notes: 1. The switch should be mounted within two metres of the cooking appliance, but not on the cooking appliance, in such a position that the user does not have to reach across the open cooking surface. 2. A single switch is permissible for the control of associated cooking appliances in the same room. 3. It is recommended that switches, particularly those in domestic installations, be marked to identify the appliances controlled. 4. This requirement is not intended to apply to enclosed cooking appliances, such as built-in ovens and microwave ovens. When in doubt, visit your local library in the reference section and look up the relevant Australian standard. Dex Induction cook tops (for those having them) just cannot be described as having an electric heating element, and secondly a Safety Switch will be in the power circuit of this device and in the event of any situation this device will operate in a zillionth of the time it takes to get to this isolation switch and operate it. Now I am no authority on this but I would be asking your electrician to show you the regulations he is working to in regard to isolation switches and Induction cook tops. barkly Re: Above counter isolation switch for induction cooktop? 15Mar 13, 2012 7:58 pm My Electrician said reason l had to have isolation switch is, if cooker (freestanding) needs maintaince/repairs before cooker is pulled out from wall this switch is precaution. l remember my mother's cooker had a switch above on wall. My DM would always say on leaving her home,l need to turn off the range meaning power to cooker. Re: Above counter isolation switch for induction cooktop? 16Mar 14, 2012 1:09 am Rogue Your sparkie is either telling fibs, or you are using something other than the generic HPM or Clipsal switch plates. We did a kitchen reno about 12 months back including new appliances, and had to install the isolation switch for the electric oven. It's a 30amp switch as well. I went to John R Turks and got the 30amp switch and a double GPO with an extra switch in the middle. Pop the 10amp switch out, push the 30amp switch in, perfect fit. Double-checked with sparkie and a Council building inspector - both gave it the thumbs up. Ovens are different to induction hotplates, induction plates have a massive current draw, that's why they heat so quickly. Our induction has a total draw of 42 amp therefore a special switch. I've just looked through the installation manual and it specified a switch with a 3mm gap between all contacts. My sparky chose the required switch based on the 42 amp. As he mentioned, that is the draw if you had every element on full which in the real world will probably never happen, however he has to work too the rated current draw so we ended up with a separate heavy duty switch tucked into the appliance hutch. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Above counter isolation switch for induction cooktop? 17Mar 18, 2012 9:12 am PHL Rogue It's a 30amp switch as well. I went to John R Turks and got the 30amp switch and a double GPO with an extra switch in the middle. Pop the 10amp switch out, push the 30amp switch in, perfect fit. Double-checked with sparkie and a Council building inspector - both gave it the thumbs up. I'll check and see if I can get a 32A switch for a Clipsal Slimline double GPO; my electrician's concern, which I confirmed with him yesterday, was the high draw when the normal switch is 10A. You can get a 35A switch in a 30 series mechanism, these are what goes into most clipsal plates. Above 35A and you need a dedicated switch plate. Re: Above counter isolation switch for induction cooktop? 18Mar 18, 2012 9:15 am pattycake4 My Electrician said reason l had to have isolation switch is, if cooker (freestanding) needs maintaince/repairs before cooker is pulled out from wall this switch is precaution. l remember my mother's cooker had a switch above on wall. My DM would always say on leaving her home,l need to turn off the range meaning power to cooker. That's a pretty silly reason in this day and age because if maintenance needs to be done it can also be turned off at the circuit breaker. Re: Above counter isolation switch for induction cooktop? 19Apr 10, 2012 11:57 pm I was always told that the isolation switch was a incase of fire safety type thing. An induction cooktop for the purpose of the as/nzs 3000 clause I would say is a heating element, it heats by induction, but saucepan on stove catch fire still producing heat! Also if you read AS/NZS 3000:2007 you will find that active and neutral are both live conductors and as such you would need to open both to satisfy the clause and a normal switch in a powerpoint will only open one wire. If it was me, as an electrician, I would not use an extra switch in a power point, and I would think it was needed! However, you could ask the regulating body in your state, energy safe Victoria in Victoria, if a switch operating a contactor which failed open would be acceptable, then the normal extra switch could operate the coil in the contactor which could be mounted in an enclosure hidden somewhere. 2 Re: Above counter isolation switch for induction cooktop? 20Apr 11, 2012 8:51 pm Quote: "-it heats by induction, but saucepan on stove catch fire still producing heat!" I just can't believe these isolation switches have anything to do with the contents of saucepans on stove tops (induction hot plates) catching fire. The last thing I would be thinking of in this situation would be to turn off the isolation switch. My actions would be very much directed at what the hell I am going to do with this fire in the saucepan. The need for an isolation switch must have some thing to do with (as above) "A circuit for fixed or stationary cooking appliance having an open cooking surface incorporating electric heating elements....." So...If the source of heat is regarded as an issue why isn't there a need for an emergency gas shut of valve for gas cook tops? Induction cook tops just do not have an open cooking surface incorporating electric heating elements. I just don't get the need for these isolation switches. Seems very much like a belt and braces approach particularly when safety switches (at the switchboard) are there to isolate when any electrical issue arises. cheers barkly Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1818 3 1631 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 12941 |
