May 26, 2013 12:20 pmSign In35 members logged in
Building Forum » Lifestyle » Home Theatre & Automation
audio from pc to stereo in another room
New Topic Post Reply  Page 1 of 1
 [ 12 posts ]
searay
 Post subject: audio from pc to stereo in another room
PostPosted: Jan 14, 2012 6:38 pm
Junior Member
Junior Member
Hi everyone
i have a pc in one room and a stereo in another room that i want to connect.
The run would be just under 30 metres through walls and roof.
the cable needs to go from 3.5mm stereo plug to 2 rca.
Should i use twin rca cable or can i use the 2 in 1 cable like used in 3.5mm stereo cable for the run?
My Build http://forum.homeone.com.au/viewtopic.php?f=31&t=47419
Pugs
 Post subject: Re: audio from pc to stereo in another room
PostPosted: Jan 14, 2012 11:10 pm
Use rg6 cable with f-type connectors, and f type to rca adaptors.. then us rca to 3.5mm cable.. well that is one option.
Quick question. How are going to control it?
Another option is a network music player... Or any media player that can do streaming... That is if you already have a wired or wifi network
Kodiak Data Cabling onFaceBook
Consult*, Design and Installation
Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms
Ask for a Quote.
*DIY DATA Cabling Is Ilegal
cray-
PostPosted: Jan 16, 2012 1:32 pm
Junior Member
Junior Member
Once again I'll suggest iTunes on the PC paired with an Apple AirPort Express hooked up to your amp, only $120 assuming you have an existing wireless network and an iPhone/iPod Touch to control it. Works well, lots of features for a reasonable price. Easy to extend the music to other rooms with extra AirPorts & powered speakers and then switch rooms on/off or change volume from the PC or iDevice.
Sorry if I'm coming off as a fanboy by always suggesting these, I'm actually an oldschool PC guy, but I just find the AirPorts Expresses really good at doing music streaming on a budget that Sonos can't touch.
paulw11
PostPosted: Jan 16, 2012 5:05 pm
+1 on Airport Express
5 acres in Hartley, NSW
Our House Blog
searay
PostPosted: Jan 17, 2012 6:10 pm
Junior Member
Junior Member
Thanks for the replys.
I do indeed have a wireless network and a tablet that i can use to control the music on the pc. I was thinking a wireless av sender receiver but might get a wireless player instead. No ipod/iphone in this house so will have to look at other things.
Cheers
Pugs
PostPosted: Jan 17, 2012 11:38 pm
rare thing..Airport express +2 < forget it is apple.. it is one of the best ways of getting music around the house bar having MRA already set up
Ask for a Quote.
paulw11
PostPosted: Jan 18, 2012 4:34 am
Cheers
If you mean that you simply don't have iPod/iPhone then you can get an 8gb iPod touch pretty cheaply - certainly cheaper than other touch screen remotes for multi-room systems. If you mean that you don't have Apple products for ideological reasons, then fair enough.
Paul
Our House Blog
mattwalker
PostPosted: Feb 07, 2012 10:29 pm
Support Team
Support Team
Have you considered any of the Sonos gear?
As long as your tablet is running android you can use it to wirelessly control the Sonos system.
If you want something portab le check out the PLAY:3 ... It packs a mean punch!
http://www.thecableconnection.com.au/de ... searchview
Australia wide Local Call - 1300 85 4441
Click here to look around: http://www.thecableconnection.com.au
fekish
PostPosted: Aug 24, 2012 2:34 pm
Bronze Member
Bronze Member
Sorry for hi jacking the thread, but i was searching this subject and this thread is what i wanted! :)
just wanted to confirm with someone: airport express is used in order to control music on the speakers. Thus need speakers + amplifier + wires. But Sonos needs only one initial port of internet connection? The speakers of Sonos do not need amplifier, and thus no wiring is required?
Sent from my XT910 using Tapatalk 2
paulw11
PostPosted: Aug 24, 2012 3:09 pm
Hi
The Airport Express doesn't have an amplifier, so you need to connect it to an amplifier or amplified speakers. The Airport Express can connect to your router via a network cable or it can join your Wi Fi network if you have another Apple base station.
The Sonos system needs the Sonos bridge which connects to your router and establishes the connection back to your PC for the Sonos players.
The Sonos Play 3 and Play 5 speakers have an amplifier built-in, so they are self-contained. The Sonos Powered Zone Player has an amplifier, so it can connect directly to speakers. The Sonos Unpowered Zone player is like the Airport Express, so you need an amplifier or amplified speakers.
Paul
Our House Blog
PHL
PostPosted: Aug 24, 2012 9:30 pm
Just also be aware that the Sonos will play a wider number of music formats (such as FLAC, a popular lossless music format) than the Airport Express can.
Also depends on how many players you want in the long term; the more players, the better the Sonos options gets.
mattwalker
PostPosted: Dec 11, 2012 8:52 pm
Support Team
Support Team
...and from this week will also play directly from your iPhone / iPod or iPad!
No need to dock anywhere any more.
 [ 12 posts ]
Users browsing this forum: No registered users and 1 guest
May 2013 Specials
2 x Espresso Table Lamps4 days leftBy Go Lights NSW
These stunning Espresso table lamps from Cafe Lighting are perfect for the bedroom or the living room. 2 of these lamps for less than $40...read more
10% off for the whole of MAY5 days leftBy SQUAREpeg - Moving Specialists VIC
Since you have the huge decision of choosing who to move with we feel it will make your life easier if we give you 10%...read more
Free Gift for all Homeone Customers5 days leftBy The Round Bath Company WA
Purchase any of our Spas from our huge range on Ebay this month, mention HOMEONE and receive a free gift with your first purchase. To...read more
Winter Rug Clearance Catalogue 11 days leftBy Harvey Norman The Carpet and Flooring Specialists ACT
Save, save, save with modern rugs, traditional rugs, shaggy rugs, wool rugs acrylic rugs and polypropylene rugs! There are many colours and designs to choose...read more
10% off 18 days leftBy PR Painting QLD
Receive up to 105 off your next Brisbane painting quote when you mention this advert...read more
Read Article: Interior Design Gets Set for Winter by Dale Alcock Homes WAInterior Design Gets Set for Winter
As the winter chill sets in, we thought now would be…
Read Article: FAQFAQ's - Onlinecarpet.com.au
Does OnlineCarpet install? Yes, OnlineCarpet will install your carpet. We are a…
Read Article: Modular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards by Modular Wall Systems VICModular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards
The industry leading supplier of stylish, cost-effective acoustic & boundary walls…
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Watch Video: The Archipelago II by Dale Alcock Homes WAThe Archipelago II
The sequel of our most popular home design, the Archipelago. For…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
