Browse Forums Renovation + Home Improvement Re: Renovating for $50k and under 2Dec 03, 2011 7:48 pm since you're now talking about $44.5k rather than $50k and assuming you aren't doing any of it yourself, you won't get it for $50k Re: Renovating for $50k and under 3Dec 03, 2011 10:00 pm Maybe. Hard to estimate without knowing the house. We renovate bathroom and kitchen for a lot less than that but we do most of the work ourselves (not waterproofing, tiling). So you would be removing a wall? If it's lower level this may not be possible. You need to check if it's load bearing. Moving the plumbing will not be cheap. I'd get a few quotes for moving the plumbing and waterproofing and tiling the new bathroom. Where are you located? Re: Renovating for $50k and under 4Dec 03, 2011 10:08 pm yeah, you need a plumber to quote on moving the plumbing around first. Then get quotes for a kitchen, new bathroom stuff and so on. I'd look for seconds, or auction like fittings (to save money) but have professionals install. Don't replace the floorboards unless it is necessary, you won't know till you pull up the floorcoverings. Stick with tiles in the wet areas, even if plain simple cheap white. Lino is no good for bathrooms normally (generally speaking). I don't know how far your plumbing is from the study, but as a guide I'd say around $5K, fittings around another $3K (depending what you get). And that's just the bathroom. Maybe think about tacking one room at a time.... good luck! A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: Renovating for $50k and under 5Dec 04, 2011 5:36 am Thank you for your responses. I'm in Melbourne (City of Banyule). The study is directly next to the current bathroom/laundry. The floorboards are rotted through in some places (which we found out when we ripped the carpet up 2 years ago and my husband's foot went through the floor!). A friend of my cousin's will give us a good deal on the floorboards (he fixed the rotted areas and polished it for nothing). Will definitely check to see if the wall is load bearing (we have a friend who is a property developer). Does it help that there are beams going across the ceiling (in terms of load bearing)? Thanks! Re: Renovating for $50k and under 6Dec 04, 2011 8:06 am You need an engineer to look at the walls. If you are putting the plumbing against the same wall but on the opposite side that will be quite easy. But you need to plumb in the toilet and wastes. Do not get a kitchen mob that comes out, for your kitchen (well maybe for some design ideas) as they are too expensive. They get the kitchen from the kitchen manufacturer then put their (huge) bit on which you pay. We draw it up ourselves (or they will send someone out to check measure) then order direct. They will install. Sorry I don't know any places in Melbourne. I think it's crazy when I hear of people paying $20K for a kitchen. Good luck. Re: Renovating for $50k and under 7Jul 17, 2012 4:36 pm travelbug You need an engineer to look at the walls. If you are putting the plumbing against the same wall but on the opposite side that will be quite easy. But you need to plumb in the toilet and wastes. Do not get a kitchen mob that comes out, for your kitchen (well maybe for some design ideas) as they are too expensive. They get the kitchen from the kitchen manufacturer then put their (huge) bit on which you pay. We draw it up ourselves (or they will send someone out to check measure) then order direct. They will install. Sorry I don't know any places in Melbourne. I think it's crazy when I hear of people paying $20K for a kitchen. Good luck. Ha ha...we were quoted $40 000 for our kitchen..(Perth) Ridiculous!! Apparently that's what it cost if we after a Polyurethane kitchen with blum draws, pull out pantry etc. $25 000 for new ensuite. What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7138 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16147 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4809 |
