Browse Forums General Discussion Re: Multiple light bulbs from one cable - is it possible?!?! 6Nov 25, 2011 10:51 am Super Nes Bare in mind what other items are going to be used on that particular power circuit It's the same as plugging a single electric toaster or electric kettle into an outlet. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6610 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36925 0 9793 |
