May 25, 2013 7:48 pmSign In62 members logged in
Building Forum » Outdoors » Pools & Spas
Pools - signs of leaking
New Topic Post Reply  Page 1 of 1
 [ 6 posts ]
Lex
 Post subject: Pools - signs of leaking
PostPosted: Jan 27, 2011 1:10 pm
Wondering if anyone can give me any clue as to what to expect to see in or around the pool when it develops a leak.
Would water literally just leak into the surrounding soil, or is there some smart plumbing that is routinely installed with pools which prevents uncontrolled leaking into the surrounding soil and perhaps channels it into some kind of disposal water pipes and into the stormwater system??
My signature is distracting people from my wise posts ...
chrisandkate
 Post subject: Re: Pools - signs of leaking
PostPosted: Jan 27, 2011 2:18 pm
Normally just leaks out.
Mates pool is leaking at the minute and the pool liner is floating on the water that can get out (very much clay soil/bad drainage)
Tome
PostPosted: Nov 16, 2011 11:27 pm
Junior Member
Junior Member
Hello, snorkles and some food dye, if you spot cracks within the pool or spa just drip a few drops of food dye along the cracks to see if the water is escaping or not, cheers.
[Signature removed]
vvs mand
PostPosted: Feb 12, 2012 11:31 am
Silver Member
Silver Member
Fill a bucket with water beside your pool. Measure the drop in water level of the bucket and that of the pool. After a week they should both have dropped by the same amount through evaporation.
If the drop in pool level is greater you have a leak
wheeliworks
PostPosted: Feb 12, 2012 4:57 pm
Online
Senior Member
Senior Member
the test sequence above is ok but is easier to place bucket on a step & fill to same level as pool . it is easier to see any difference in levels.
is pool concrete , fibreglass or liner. if fibreglass it will have a stand pipe fitted at the deep end . see if there is any water at bottom of pipe. if there is test it for traces of chlorine if there is you have a leak. use food colour test around hydrostatic valve first then fittings & lights if nothing there check any areas around pool that look like a possible crack.
cheers andrew
jaelee
PostPosted: Mar 16, 2012 1:41 pm
We had a leak, and could tell by the water level dropping. We did the bucket test too, that's a great idea and gives you an idea on how quickly you are losing the water.
Turned out we had a hole which they pool installers came out and plugged up with aqua putty and colour matched it to the pool. this was just over a year ago and it's still all in place.
We had to be quite forceful to the pool company that we had a leak, they said it was "impossible"
 [ 6 posts ]
Users browsing this forum: No registered users and 1 guest
May 2013 Specials
Mammoth May Markdowns - 3 Days Only!Ends todayBy Harvey Norman The Carpet and Flooring Specialists NSW
Solution Dyed Classic Carpet for $14.95 sqm and many more mammoth flooring markdowns in store. Don’t Miss Out! ...read more
2 x Espresso Table Lamps5 days leftBy Go Lights NSW
These stunning Espresso table lamps from Cafe Lighting are perfect for the bedroom or the living room. 2 of these lamps for less than $40...read more
10% off for the whole of MAY6 days leftBy SQUAREpeg - Moving Specialists VIC
Since you have the huge decision of choosing who to move with we feel it will make your life easier if we give you 10%...read more
Free Gift for all Homeone Customers6 days leftBy The Round Bath Company WA
Purchase any of our Spas from our huge range on Ebay this month, mention HOMEONE and receive a free gift with your first purchase. To...read more
10% off 19 days leftBy PR Painting QLD
Receive up to 105 off your next Brisbane painting quote when you mention this advert...read more
Read Article: Interior Design Gets Set for Winter by Dale Alcock Homes WAInterior Design Gets Set for Winter
As the winter chill sets in, we thought now would be…
Read Article: FAQFAQ's - Onlinecarpet.com.au
Does OnlineCarpet install? Yes, OnlineCarpet will install your carpet. We are a…
Read Article: Modular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards by Modular Wall Systems VICModular Wall Systems wins Industrial Product of the year and Steel Innovation of the year Awards
The industry leading supplier of stylish, cost-effective acoustic & boundary walls…
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Watch Video: The Archipelago II by Dale Alcock Homes WAThe Archipelago II
The sequel of our most popular home design, the Archipelago. For…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
