Browse Forums Lighting + Lighting Design Re: Recomendations for lighting - Perth 2Mar 30, 2011 2:15 pm Building with Life$tyle Homes in Perth SOR Key Dates on First Page of my Thread viewtopic.php?f=31&t=38761 Re: Recomendations for lighting - Perth 5Mar 30, 2011 3:56 pm Building with Life$tyle Homes in Perth SOR Key Dates on First Page of my Thread viewtopic.php?f=31&t=38761 Re: Recomendations for lighting - Perth 6Mar 30, 2011 4:05 pm uncle tonksy what he said! oh wait, no. I want the electrician to quote on install and supply. Re: Recomendations for lighting - Perth 8Mar 30, 2011 4:18 pm same. Would like to limit the LED's because of price, to the main areas. I think last count was somewhere in the 40 lights area? Re: Recomendations for lighting - Perth 11Jul 07, 2011 3:11 pm bump. would also like an electrican SOR - and an approximate price they charge per downlight Re: Recomendations for lighting - Perth 13Aug 09, 2011 1:42 am Hi, I'm also looking for a reliable and reasonable electrician SOR - can you please send me their details as well? Thanks! Re: Recomendations for lighting - Perth 14Apr 29, 2013 7:43 pm wrexter keen to know as well. i have installed clipsal 413 all over, so all a sparky would have to do it put downlight in and plug in the light. im planning on doing the light markings, drilling and fitment. i will also supply the lights. just need a sparky to do the connections so its all legit Hi Wrexter or anyone... I'm trying to figure out what to do in terms of getting the lighting sorted during our pre start appointment... we want downlights installed ourselves not through the builder... but im not sure how i go about it in terms of getting sorted properly so its easy for when i get a sparky to come in and do it after we get our keys... when you say you installed clipsal 413 all over... are you able to elaborate a bit further... Re: Recomendations for lighting - Perth 15May 08, 2013 12:56 am happytaurus wrexter keen to know as well. i have installed clipsal 413 all over, so all a sparky would have to do it put downlight in and plug in the light. im planning on doing the light markings, drilling and fitment. i will also supply the lights. just need a sparky to do the connections so its all legit Hi Wrexter or anyone... I'm trying to figure out what to do in terms of getting the lighting sorted during our pre start appointment... we want downlights installed ourselves not through the builder... but im not sure how i go about it in terms of getting sorted properly so its easy for when i get a sparky to come in and do it after we get our keys... when you say you installed clipsal 413 all over... are you able to elaborate a bit further... Rather than having the builders electricians mark the 'center' of your room or wherever desired and having them place a batten holder, get your builder to just put 413's in nominated positions for where you would like downlights. That way, the ceiling is unmarked, and all an electrician would do would be mark out the position, cut & install. You'll find if you go with the builder placing batten holders in rooms, a good portion of the time a timber structure runs through right next to their light. In terms of downlights, you need clearance from said timbers and you'll be left with a hole to patch/paint etc. 413's are just unswitched socket outlets that downlights plug in to. Search 'clipsal 413' to see what they look like. I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16772 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29191 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9190 |
