Browse Forums Building A New House Re: Sezza's Build SOR Perth. waiting.. waiting... 341Feb 18, 2011 5:49 pm Built with Sw1tch H0mes >Build thread< House status 15/12: Gates and A/C finally installed! Sep 09 Bought block, Dec 09 Engaged builder, Jul '11 Moved in Re: Sezza's Build SOR Perth. waiting.. waiting... 342Feb 18, 2011 7:52 pm Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Sezza's Build SOR Perth. waiting.. waiting... 343Feb 19, 2011 2:41 am SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Build 344Feb 21, 2011 11:15 pm SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build 345Feb 22, 2011 11:31 am my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Sezza's Perth Build 346Feb 22, 2011 12:57 pm contract 10/11 prestart 04/10 slab 06/10 bricks 07/10 roof 09/10 plaster 10/10 Ceiling 10/10 LOCKUP 10/10 tiling wet areas 11/10 garage floor 11/10 PCI 12.01.11 handover 11.02.11 https://forum.homeone.com.au/viewtopic.php?f=31&t=39361&hilit=malvern+springs We are in !!! Re: Sezza's Perth Build 347Feb 22, 2011 3:51 pm I heard that the sealer is pretty potent - DH is going to get some special masks from his work and we will do the job in stages and isolate the areas until the smell is gone... what choice do we have? I was hoping to move in after the painting was done but it's not to be... Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Sezza's Perth Build 348Feb 22, 2011 3:53 pm You can Bags. The problem in my house was that the painters closed all the windows after they put the sealer. But after I ventilated next day and once the paint went on - it was OK. contract 10/11 prestart 04/10 slab 06/10 bricks 07/10 roof 09/10 plaster 10/10 Ceiling 10/10 LOCKUP 10/10 tiling wet areas 11/10 garage floor 11/10 PCI 12.01.11 handover 11.02.11 https://forum.homeone.com.au/viewtopic.php?f=31&t=39361&hilit=malvern+springs We are in !!! Re: Sezza's Perth Build 349Feb 22, 2011 8:26 pm partner was thinking of paying a painter to do the sealer. but wonder how fussy they would be with the initial prep work???? def need to air the house out when paiting.. let all the fumes out!!!! not bad idea.. getting some sort of mask to stop breathing all those fumes!!! or even one of those space man suits!!!!! you always seem to get covered in paint even tho you try to be soo careful!!!! SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build 350Feb 22, 2011 8:30 pm And the whole fun begins when you try to get it out of your hair I think with the price of sealant being so low it's not really worth to pay someone to do it. Bunnings sells it in those bottles like for pest control so you just pump it up and it sprays. And they are around $60 for I think 5 litres contract 10/11 prestart 04/10 slab 06/10 bricks 07/10 roof 09/10 plaster 10/10 Ceiling 10/10 LOCKUP 10/10 tiling wet areas 11/10 garage floor 11/10 PCI 12.01.11 handover 11.02.11 https://forum.homeone.com.au/viewtopic.php?f=31&t=39361&hilit=malvern+springs We are in !!! Re: Sezza's Build SOR Perth. tiling completed. 351Feb 22, 2011 11:09 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tapware - flickmixers, wont fit behind our above bench sinks like we had 1st picked. in the ensuite to the left of the left basin and on the right to the right. that way they arent in the way of feature tiles in the ensuite?!?!?!?! or both to the same side???? and in vanity area to the right, so when you first walk in you dont just see tap???? what are your thoughts???? SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build.. what do you think??? 352Feb 23, 2011 9:34 am I'd put them on the outside, away from the tiles Looking gorgeous sezza my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Sezza's Perth Build.. what do you think??? 353Feb 23, 2011 10:24 am thanks for the feedback tinkster!!!! its funny how such little things can do your head in!!!! SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build.. 354Feb 24, 2011 9:42 am our block has now been cleared!!! the huge rubbish pile has now gone. no PCI this week. but maybe what you could call a inspection before PCI!!!!!! at least its something. so hopefully come real PCI most things would have been fixed. SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Build SOR Perth. tiling completed. 355Feb 24, 2011 3:01 pm sezza Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tapware - flickmixers, wont fit behind our above bench sinks like we had 1st picked. in the ensuite to the left of the left basin and on the right to the right. that way they arent in the way of feature tiles in the ensuite?!?!?!?! or both to the same side???? and in vanity area to the right, so when you first walk in you dont just see tap???? what are your thoughts???? We picked ours to be on the left and right corners. I noticed it in this display..... they did the iside corners? I did the outside... I have the same basins as these... gets me excited! http://www.lifestylehomes.com.au/Our-Ho ... ngton.aspx Just scroll through to find the bathroom image. Your basins, are stunning BTW. Building with Life$tyle Homes in Perth SOR Key Dates on First Page of my Thread viewtopic.php?f=31&t=38761 Re: Sezza's Perth Build.. 356Feb 24, 2011 6:00 pm No more rubbish out the front!!!!! our pile was collecting all sorts, other than normal building rubbish. at one stage there was a couch, a car trye!!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ we are going into the house today. looking forward to that. hopefully not too many faults to pick. and if there is hopefully they will be sorted before real PCI. and then keyzzzzzzzz......................!!!!! just found out bout the long weekend coming up in april. sat, sun, mon, tues off for me for anzac day and easter...... will be in the house by then so pefect time to get stuck into stuff!!! SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build.. inspection before real PCI today!! 357Feb 25, 2011 12:39 pm Nice clean site As to your tapware I think it will look more interesting if they will go on the site but closer to the wall - like 45 degrees from wall - if you know what I mean contract 10/11 prestart 04/10 slab 06/10 bricks 07/10 roof 09/10 plaster 10/10 Ceiling 10/10 LOCKUP 10/10 tiling wet areas 11/10 garage floor 11/10 PCI 12.01.11 handover 11.02.11 https://forum.homeone.com.au/viewtopic.php?f=31&t=39361&hilit=malvern+springs We are in !!! Re: Sezza's Perth Build.. inspection before real PCI today!! 358Feb 25, 2011 8:33 pm the taps are going to be positioned at the side of the sink but towards the back. is this the same as what you mean agabob??? SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build.. inspection before real PCI today!! 359Feb 25, 2011 8:43 pm ok... "dear house build diary!!!" today we had a walk through of the house. I guess you could call it the PCI before PCI!!! not alot to worry about that we noticed.... only things that we picked up were: 1 of the linean doors on the inside wasnt painted. on the driveway and at the path near the front door our darker boarder pavers, 1 of them is chipped and another has a defect in it. like a marble effect with limestone!!! there was a hole in one of the bedroom walls, but ths has already been patched up ceilings where they were cracked have also been fixed up. hmmmmmmm. thats all i can really think of at the moment. lights work, taps work, loos flush, garage door works. what else should i look out for?!?!?!?! SEZZA'S BANKSIA DESIGNER viewtopic.php?f=31&t=33423 Building with SPH SOR - Baldivis. 3/5/10 Prestart 30/5/10 Final Plans Arrive 18/8/10 Siteworks 26/8/10 Slab 14/9/10-14/10/10 Bricks (2 Man Team) 25/10/10 Roof Frame and Roof Tiles 15/11/10 Rendering -Inside walls and Front of House Lock up and Locked Out!!! 10/12[/size] Re: Sezza's Perth Build.. inspection before real PCI today!! 360Feb 26, 2011 1:48 am Sounds like it's all ready to go then sezza. That is quite 'generous' of your builder to have a pre-PCI inspection! Makes sense though. Take a look here for some good PCI checklists: http://www.anewhouse.com.au/?page_id=235 Built with Sw1tch H0mes >Build thread< House status 15/12: Gates and A/C finally installed! Sep 09 Bought block, Dec 09 Engaged builder, Jul '11 Moved in Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19601 1 5033 1 2857 |
