And Mr Sheen is silicon...
Browse Forums DIY, Home Maintenance & Repair Re: Any hints for window cleaning? 29Jul 30, 2010 9:03 am Here is the reply from Interpon (owns Courtaulds, Dulux, Akzo Nobel, etc.). Quote: We normally recommend automotive detergents as these are specifically designed to be applied over a coated surfaces. The key issue is to ensure the detergent used is "pH neutral" and the cleaned area is thoroughly rinsed with fresh water after cleaning. We would recommend that the cleaner you propose to use checked to ensure its is "pH neutral", diluted and evaluated on a section prior to cleaning or maintaining a larger powder coated section. Note
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Any hints for window cleaning? 30Jul 30, 2010 3:52 pm homeonline 1. Ensure that the cleaning direction is only one way. I read somewhere (can't remember where) that you should clean each side of the window in a different direction (eg, inside up and down and outside left and right), that way, if you end up with streaks, you know which side of the window to re-wash Re: Any hints for window cleaning? 31Jul 30, 2010 4:04 pm I use Enjo products when cleaning my windows. They have a window cleaning head that has a fibre on one side and squeegy (sp?) on the other side so you clean with the fibre and remove most of the water with the squeegy and then I completely dry it with a seperate microfibre cloth and haven't had any issues with streak marks Re: Any hints for window cleaning? 32Aug 01, 2010 3:48 pm Dishwashing liquid vs Car wash - My tender hands prefer car wash. The dishwashing liquid (even for sensitive hands) dry my hands out in minutes, but the car wash has not effected them. Sorry, no scientific theory attached. Re: Any hints for window cleaning? 36Aug 26, 2010 11:25 pm I just use a damp cloth (just water to make it damp) and then a dry cloth. It will come up perfect. If the window is really grubby, then a go over with some vinegar in water then the above procedure. Re: Any hints for window cleaning? 37Aug 31, 2010 8:48 pm I have detailed many cars in the past including some show cars. Best I have found for quick, streak free cleen is Metholated Spirits from a spray bottle and newspaper. Give it a shot and you won't look back. Re: Any hints for window cleaning? 38Sep 01, 2010 12:57 pm Tornado_ALIVE I have detailed many cars in the past including some show cars. Best I have found for quick, streak free cleen is Metholated Spirits from a spray bottle and newspaper. Give it a shot and you won't look back. I just heard this tip from a friend today. Do you diluate the metho with water though? Renovating our 1970s home No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 5142 Yep, efflorescence as mentioned above. You could look to clean it with a "acid" based cleaner and then seal with a penetrating sealer. This may not stop it entirely but… 3 6512 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 6219 |
