Browse Forums Feng Shui Re: Kitchen and bathroom share a common wall. Is this bad? 3Sep 23, 2009 6:32 pm Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Re: Kitchen and bathroom share a common wall. Is this bad? 9May 16, 2010 4:25 pm edensmist My kitchen and bathroom/toilet share a common wall. It supposedly affects your finances. That explains it! Re: Kitchen and bathroom share a common wall. Is this bad? 10May 24, 2010 1:22 pm edensmist My kitchen and bathroom/toilet share a common wall. I've heard that this is bad Feng shui. It supposedly affects your finances. Can anyone clarify if this is correct? From that basic information, as it has next to zero effect on the flows of Chi around your house, there is no reason for this to have any affect on your finances. This is where Feng Shui gets a bad name, where people know enough to be dangerous but not enough to be useful. Yes the bath room represents removal of waste, and the kitchen represents wealth and prosperity. But that doesn't mean putting the two back to back with a wall between them that you will remove your prosperity. The wall separates the flows of Chi from either room, and unless there is a door between them, will negate any affect of one on the other. I would be more worried about if a toilet is opposite the front door or at the centre of the house. Re: Kitchen and bathroom share a common wall. Is this bad? 11Nov 26, 2012 10:27 pm If you seriously consider feng shui in your home, then it's bad especially if the sink and toilet bowl are back to back. You can check some feng shui websites. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10033 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4211 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 |
