Browse Forums Lighting + Lighting Design Re: Raked Ceiling Downlights 5Apr 24, 2010 6:41 am Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Raked Ceiling Downlights 8Apr 27, 2010 10:45 pm Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Raked Ceiling Downlights 9Apr 28, 2010 12:38 pm cenemelectrical hello, The difference between a cfl and a downlight is a downlight runs a lowvoltage transformer and a low voltage globe ( usually 12v 50w ) a cfl runs on 240v There are a few issues with cfl lights - there have a large diameter - they have a very deep mounting depth - take twice as long to fit-off - they catch spider webs and bugs - theytend to discolour over time - they wont work on a raked ceiling because they cannot be adjusted to point down. you will end up with light point to the walls creating light circles on the walls and dark spots The reason why your sparky is insisting to install downlights is because they will perform much better on a raked situation... You can replace downlight globes with led globes but only certain types. If you get the wrong ones you will have to replace all the transformers to accomodate. Just a couple of questions if you pop back in cenemelectrical.. The deep mounting depth does worry me - we don't have a lot of room to play with, hence all this research. I need to see what kind of covers would be required and if would would have sufficient clearance. What do you mean, twice as long to fit off? Do you mean install? Without transformers I make the assumption there would be less work, am I wrong? The fittings I am looking at have glass covers - I am not sure why they would attract anymore bugs than halogens? I think the CFL globes may go a little yellow when nearing the end of their lives, is that what you mean about discolouration? I think I mentioned my concern about the direction of light in my original post - our sparky was supposed to bring a fitting for me to try but he has been busy and unable to. I will try to see the effect of the direction before making a decision. I have the wiring in for 6 down lights and a fan for the living/dining, also 3 pendants and 3 down lights for the kitchen. I am considering looking at having alternative fittings over the living/dining where the ceiling is high - simply because of the hassle involved. Although it does involve moving the wires there is no gyprock as yet so no big deal - It is simply disappointing as I wanted the majority of lighting to fade into the ceiling. Re: Raked Ceiling Downlights 10Apr 28, 2010 3:46 pm hello, The discolouration ususally is a result of cheap fittings. be it a downlight, cfl downlight or any other fitting. The mounting depth of the lights will not be an issue in your situation. As seen by your photo the trusses you are using in your ceiling will have more than enough depth. also remember you will have an extra 30-40mm to play with becuase of ceiling battons ( this is what the plaster is screwd to ) and the plaster itself ( usualy around 10-16mm ) Just make sure the insulation guys leave a a large space where you plan to have to lights installed. Many builders overlook this area. Fitting-off means the final stage of an electrical installation before commisioning where all the fittings are installed ( switches/lights/gpo's etc..) a cfl downlight take longer to install because of the annoying terminals that are common place on these type of lights. A downlight is quick and easy to install. Depending on your electrician, you may get charged extra to fit pendant fittings as they can take longer to fit. hope this helped Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Raked Ceiling Downlights 11Apr 28, 2010 4:08 pm not sure if you are still worried about the direction issue, but my parents have a downlight over their sink on an angled ceiling and they still have the downlight shine down rather than on the angle. so it can be done. for the height, we have a couple of downlights in our kitchen with 3m ceilings, they are fine lightwise. (but they are halogens) "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Raked Ceiling Downlights 12Apr 28, 2010 9:31 pm Thanks so much for answering my questions Another consideration is going with this type: http://www.environmentshop.com.au/Produ ... p?PID=2863 Is it silly to hope that they will figure out a new globe to fit in these with higher light put put in the future? And then placing a pendant like this: http://www.beaconshop.com.au/components ... life12.jpg in the centre of the room in place of a fan for now. Re: Raked Ceiling Downlights 13Jan 17, 2012 10:35 am Just wondering how you went Robbo3, if you're still around the forums. My partner and I are building a house (currently in for council approval) and we have to make decision on the lights for our raked ceiling. We're going with LED downlights and were given the following tips by a lady who works at a lighting store: - To make sure the downlights are gimbal so they can point down even on the rake - Check that the lights have a minimum of 60degree beam and between 620-720 lumens The part we're finding the hardest is choosing the pendant lights for above our kitchen island. I have a very particular type in mind (clear glass , dome-shaped) and I'm having trouble sourcing it. On top of that, I'm unsure of how many to get. I don't want them to dominate the space but they need to be large enough to be practical and look "right." Anyway, good to see there are a few struggling with the decision like us I guess. Phew! Re: Raked Ceiling Downlights 14Nov 27, 2013 7:51 pm These old topics are very useful! We are trying to work out if not using gimballed downlight in a raked ceiling will be an issue... the builder has come back and said they are double the price! Anyone got an oppinion on if it is worth the cost....? We'd need to do this to 8 lights = +$1,200, which is a lot given our upgraded electrical plan is already $5k (then add all the other upgrades). Can be be done cheaper, after? Re: Raked Ceiling Downlights 15Dec 27, 2013 5:58 pm we have raked ceilings right through the lounge, kitchen and family room (they all run along the front of the house). It goes from 3m to about 5m in height. We put LED lights thoroughout - all with gimble fittings..We bought them from China. We put 10w in the front rooms and 8w in all other rooms (2.4m high). Warm white. 120 degree beam. Our sparky says it is the best he has seen - good even light throughout..and he loved the quality of the fittings and globes) we have used lots of lights as we hate looking at project homes that barely have enough lights in them. In the lounge area which is about 7m x 10m we have 24 lights (150 throughout the house). We couldnt find the gimble fittings here that we liked - all cheap looking and too large gaps around the gimbles....we spent a LONG time sourcing what we got, and are very happy with them.. (We had to buy 500 - so we actually have 300 left - if anyone is interested - not globes - just gimble fittings - 90mm cut out - white matt finish). Re: Raked Ceiling Downlights 16Jan 08, 2014 7:08 pm Guys, please remember, buying anyting from China is risky. Please make sure they are certified, comply with Australian Standards and QC tested. If anything goes wrong, you WILL NOT be covered by insurance. We've seen this happen countless times, and really not worth seeing you house burn to the ground, and not being covered by insurance because thinking that saving some money was the best option. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: Raked Ceiling Downlights 17Jan 08, 2014 7:11 pm ours comply with all regulations and have all the certificates, so no problems Re: Raked Ceiling Downlights 18Jan 17, 2024 3:34 pm chatterbox we have raked ceilings right through the lounge, kitchen and family room (they all run along the front of the house). It goes from 3m to about 5m in height. We put LED lights thoroughout - all with gimble fittings..We bought them from China. We put 10w in the front rooms and 8w in all other rooms (2.4m high). Warm white. 120 degree beam. Our sparky says it is the best he has seen - good even light throughout..and he loved the quality of the fittings and globes) we have used lots of lights as we hate looking at project homes that barely have enough lights in them. In the lounge area which is about 7m x 10m we have 24 lights (150 throughout the house). We couldnt find the gimble fittings here that we liked - all cheap looking and too large gaps around the gimbles....we spent a LONG time sourcing what we got, and are very happy with them.. (We had to buy 500 - so we actually have 300 left - if anyone is interested - not globes - just gimble fittings - 90mm cut out - white matt finish). Chatterbox - it's so long since you wrote this post - but do you still have these gimbles? What are the specs of the fittings? We are having raked ceilings in our living/dining/kitchen area, and it just occurred to us to look into this! Thanks in advance Re: Raked Ceiling Downlights 19Jan 17, 2024 4:42 pm yes we do have these - havent got around to advertising them lol. I can do some pictures and send them through. Not sure if you can post an email address here, or maybe call me on 0418 817 816 Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 2063 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6300 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2538 |
