Browse Forums Feng Shui Re: Kitchen and bathroom share a common wall. Is this bad? 3Sep 23, 2009 6:32 pm Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Re: Kitchen and bathroom share a common wall. Is this bad? 6Oct 07, 2009 12:59 pm edensmist Thank you Loktin for your reply. Yes the stove and toilet are back to back on a common wall. Do you know of any feng shui cures to remedy this? The best I suggest is to see which one, the stove or the toilet is more easy to move! Cheers! Edgar (Lok Tin) Yung Re: Kitchen and bathroom share a common wall. Is this bad? 7Oct 21, 2009 1:02 am edensmist My kitchen and bathroom/toilet share a common wall. I've heard that this is bad Feng shui. It supposedly affects your finances. Can anyone clarify if this is correct? We are renovating the house so we may be able to relocate the toilet but it will be expensive so I'd rather not do it if it's not necessary. Does anyone know if there are any Feng Shui cures for this? nothing bad about it. dont worry too much. Re: Kitchen and bathroom share a common wall. Is this bad? 8May 05, 2010 5:52 pm Quote: The kitchen should neither face the front nor back door or the staircase or bathroom or an adjoining room as such a placement encourages bad health, arguments among family members and overall bad luck. Bit hard to have a kitchen not faceing any adjoining room Well, certainly not in open space designs Our kitchen in previous house had a door to hallway and one to laundry and front opened to the dining area - current kitchen opens to dining/family area - this covering the last 24 years of my life; surprisingly I have been in very good health and happiness. Re: Kitchen and bathroom share a common wall. Is this bad? 9May 16, 2010 4:25 pm edensmist My kitchen and bathroom/toilet share a common wall. It supposedly affects your finances. That explains it! Re: Kitchen and bathroom share a common wall. Is this bad? 10May 24, 2010 1:22 pm edensmist My kitchen and bathroom/toilet share a common wall. I've heard that this is bad Feng shui. It supposedly affects your finances. Can anyone clarify if this is correct? From that basic information, as it has next to zero effect on the flows of Chi around your house, there is no reason for this to have any affect on your finances. This is where Feng Shui gets a bad name, where people know enough to be dangerous but not enough to be useful. Yes the bath room represents removal of waste, and the kitchen represents wealth and prosperity. But that doesn't mean putting the two back to back with a wall between them that you will remove your prosperity. The wall separates the flows of Chi from either room, and unless there is a door between them, will negate any affect of one on the other. I would be more worried about if a toilet is opposite the front door or at the centre of the house. Re: Kitchen and bathroom share a common wall. Is this bad? 11Nov 26, 2012 10:27 pm If you seriously consider feng shui in your home, then it's bad especially if the sink and toilet bowl are back to back. You can check some feng shui websites. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10976 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4657 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16529 |
