Browse Forums Building A New House Re: Storm water drains and soakwells 2Sep 03, 2009 10:15 pm Building with CELEBRATION HOMES @ THE GLADES in BYFORD W.A. My Build thread: viewtopic.php?f=31&t=19512&p=249550#p249550 Re: Storm water drains and soakwells 4Sep 04, 2009 7:29 am Building with CELEBRATION HOMES @ THE GLADES in BYFORD W.A. My Build thread: viewtopic.php?f=31&t=19512&p=249550#p249550 Re: Storm water drains and soakwells 6Sep 04, 2009 4:17 pm Building with CELEBRATION HOMES @ THE GLADES in BYFORD W.A. My Build thread: viewtopic.php?f=31&t=19512&p=249550#p249550 Re: Storm water drains and soakwells 9Sep 07, 2009 11:55 pm *Built with Gemmill Homes in WA* Slab - 1st June 2009 Plate Height - 17th June 2009 Lock Up - 18th August 2009 PCI - 5th October 2009 Hand Over - 15th Oct 2009 https://forum.homeone.com.au/viewtopic.php?f=31&t=20844 Re: Storm water drains and soakwells 11Sep 08, 2009 12:59 am *Built with Gemmill Homes in WA* Slab - 1st June 2009 Plate Height - 17th June 2009 Lock Up - 18th August 2009 PCI - 5th October 2009 Hand Over - 15th Oct 2009 https://forum.homeone.com.au/viewtopic.php?f=31&t=20844 Re: Storm water drains and soakwells 18Sep 17, 2009 5:51 pm Instead of as many soakwells people could consider a rainwater tank. I am required to either have rainwater or greywater system. Not looking forward to soakwells - did it earlier this year at in our established home with the huge concrete ones - what a mission! Re: Storm water drains and soakwells 19Sep 17, 2009 11:39 pm OK so i'm back at this again... The builder have come back with a cost of over $2000 to put run pipework from the down pipes to the storm water drain. Personally i think this is stupidly rediculously overpriced. So the question is.. How much did you all pay for your stormwater connections? Re: Storm water drains and soakwells 20Sep 18, 2009 11:57 am elemist OK so i'm back at this again... The builder have come back with a cost of over $2000 to put run pipework from the down pipes to the storm water drain. Personally i think this is stupidly rediculously overpriced. So the question is.. How much did you all pay for your stormwater connections? Mine is just listed in my site-works inclusions. It does not have a breakdown of costs just a list and a final inclusions cost. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7901 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6895 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10600 |
