Browse Forums Heating, Cooling & Insulation 1 Mar 27, 2009 8:32 pm --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Insulation Requirement .. R ? & Sarking ? 3Mar 28, 2009 9:47 am --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Insulation Requirement .. R ? & Sarking ? 10May 07, 2009 12:42 pm There is lots of options, but what sort of roof do you have (metal / tile / other) - is it pitched or flat or skillion? dynomite is right, you will get a big benefit from the relective properties of sarking, and anticon or air-cell provide bulk insulation benefits as well. If you have a flat roof I think sarking is required by building code, but steeply picthed metal you don't have to (but you should!). The pay back in reduced heating costs will be very short. Re: Insulation Requirement .. R ? & Sarking ? 11May 07, 2009 1:12 pm lambchoppa There is lots of options, but what sort of roof do you have (metal / tile / other) - is it pitched or flat or skillion? dynomite is right, you will get a big benefit from the relective properties of sarking, and anticon or air-cell provide bulk insulation benefits as well. If you have a flat roof I think sarking is required by building code, but steeply picthed metal you don't have to (but you should!). The pay back in reduced heating costs will be very short. Sorry to hijack the thread We'll have a tile roof (25 degree pitch). What would you recommend? Re: Insulation Requirement .. R ? & Sarking ? 12May 10, 2009 11:17 pm I am assuming it is a new house and you are located in adelaide ... it is pretty easy, I would just use any reflective foil sarking (www.bradfordinsulation.com.au, www.air-cell.com.au) under the tiles, ensuring its 'sags' ie has an airspace between it and the tiles and then use well installed (no gaps) bulk insulation (batts) directly on the ceiling between the joists. This should give you the right balance. Sarking improtant under metal roofs for condensation less so under tiles, but essential because of its reflective properties - ie keeping out summer heat. Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15841 Building Standards; Getting It Right! Hi all Iām in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 14263 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11446 |
