Hi,
Just wondering if anyone has priced Double Aluminium doors. We have been quoted about $800. is this reasonable.
Browse Forums Windows & Doors 1 Apr 30, 2009 1:30 pm Hi, Just wondering if anyone has priced Double Aluminium doors. We have been quoted about $800. is this reasonable. If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. Re: Aluminium double doors 2Apr 30, 2009 1:33 pm More info please? Type? Colour? Brand? Application? Installation? Delivery? Supply only? Etc Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Re: Aluminium double doors 3Apr 30, 2009 1:59 pm BUILDERSEDGE More info please? Type? Colour? Brand? Application? Installation? Delivery? Supply only? Etc Ben Just white aluminium double doors - supply only. If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. Re: Aluminium double doors 4Apr 30, 2009 2:18 pm Doesn't sound to bad Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Re: Aluminium double doors 5Apr 30, 2009 2:47 pm I am having the builder come around tonight to quote installation what would you say the ball park for this would be. I need a single double hung window taken out and then the opening made wider to install the double doors. If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. Re: Aluminium double doors 6Apr 30, 2009 6:54 pm Looks like a good price. For ours it's a variation in the contract.... Provide FD2210 French doors in lieu of 25 x 2210 sliding door $1,715 Provide FD2210 French doors in lieu of 25 x 2210 sliding window $1,355 They look like this....(see file attachment) IMG_0751.jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Aluminium double doors 7Apr 30, 2009 7:01 pm price seems ok, i was quoted 720 i think for mine from a local company which i got all my windows from Re: Aluminium double doors 8Apr 30, 2009 7:36 pm Wingies I am having the builder come around tonight to quote installation what would you say the ball park for this would be. I need a single double hung window taken out and then the opening made wider to install the double doors. It will depend on a couple of things: (1)Does the timber lintel need to be changed due to spanning a bigger distance? (2)Removal of existing window (3)Cut remove brickwork/cladding (4)Removal of plaster, installation of window studs (5)Marrying th enew sill into the floor, is it timber, concrete, carpet??? (6)Any services need relocating (electrical, plumbing etc) (7)Supply and install of new architraves, mods to skirting etc (8)Does the steel brick lintel need to be changed due to increased span? If it was a straight cut out old window and fit new doors, should only be around $800-$1000, obviously the more work involved etc the price will go up. We did a job for a client like this, we had to cut the double brick work out, and install steel lintels to both sides of the brick work, built a custom reveal (250mm+) Married the new sill into the timber floor, skirting and architraves to both sides of the new window was around $3500 for two windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As you can see on the left hand side, the smaller window of the two has had the arcs put on and the sliding door was just about to have its archs installed. We went to big lenghts to cover everything in plastic, as we had to wet cut with a demo saw inside the house. Hope this gives you an idea of whats involved. Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Re: Aluminium double doors 9Apr 30, 2009 7:48 pm sounds about right depending on if its supply and install as well (you will need to consider the door frame as well) if in doubt the cheapest guys we use are Custom aluminium windows - 0411423465 good luck Re: Aluminium double doors 10May 01, 2009 9:24 am BUILDERSEDGE If it was a straight cut out old window and fit new doors, Yep this is exactly what it is. We are renoing the Kitchen so the plaster will be off the wall and there is no electrical or such up that end of the wall. The builder didn't turn up last night so coming tonight, I know have a bit of an idea what he might be looking at so I can see what he thinks. Will let you know what the quote ends up being. Thanks for your help. If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16346 4 14519 |
