Browse Forums Building Standards; Getting It Right! Re: Gaps/spaces between floor boards and skirting boards 2Mar 17, 2024 9:10 pm We are Expert Consultant's, and we are here to help. Re: Gaps/spaces between floor boards and skirting boards 3Mar 17, 2024 10:30 pm BuildingandLegal If this is a floating floor or laminate floor then your supervisor is correct. Does it include vinyl? Re: Gaps/spaces between floor boards and skirting boards 4Mar 18, 2024 1:21 pm I would be asking building supervisor to show me in writing why the warranty would be voided Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Gaps/spaces between floor boards and skirting boards 5Mar 18, 2024 1:52 pm building-expert I would be asking building supervisor to show me in writing why the warranty would be voided That’s what we did. Thank you. Re: Gaps/spaces between floor boards and skirting boards 7Apr 22, 2024 6:28 pm FloorzHmm We have the same issue. Did you get any answers or have it rectified ? Apparently, it should be that way. They can’t put any silicone as floating boards move and if they put any adhesion, over time, the floors will buckle. Re: Gaps/spaces between floor boards and skirting boards 8Apr 22, 2024 7:25 pm Lea Santos FloorzHmm We have the same issue. Did you get any answers or have it rectified ? Apparently, it should be that way. They can’t put any silicone as floating boards move and if they put any adhesion, over time, the floors will buckle. Is it clix 7mm laminate by any chance? Re: Gaps/spaces between floor boards and skirting boards 9Apr 22, 2024 7:27 pm FloorzHmm Lea Santos FloorzHmm We have the same issue. Did you get any answers or have it rectified ? Apparently, it should be that way. They can’t put any silicone as floating boards move and if they put any adhesion, over time, the floors will buckle. Is it clix 7mm laminate by any chance? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 836 7 3426 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1066 |
