Browse Forums Building A New House Re: Crooked wall or cornice? 3Mar 14, 2024 2:56 pm We are Expert Consultant's, and we are here to help. Re: Crooked wall or cornice? 5Mar 14, 2024 3:24 pm We are Expert Consultant's, and we are here to help. Re: Crooked wall or cornice? 8Mar 15, 2024 9:15 am Whydidibuildagaib ponzutwo Whydidibuildagaib Cornice guy says he’ll try something to make it less obvious so will see what he does. Frame def was out by .5-6 i.e gradually got worse the higher I measured hence why the tolerances on plumb, straightness etc. are over 2M. It getting gradually worse over the length is not ok. Should have been checked before plaster then packed or straightened to ensure plaster went on properly. That was framers job, not the plasterers. Not an excuse for the plasterers poor job, but just so you're aware of what the genesis of the issue is. Funny enough the builder makes their own frames so it’s the builders fabrication issue (steel framing) same thing. Not the plasterers job to fix the plumbness of the frame is what i was getting at Re: Crooked wall or cornice? 9Mar 16, 2024 9:39 pm The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should fix it back within tolerance. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6763 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5574 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17878 |
