Browse Forums DIY, Home Maintenance & Repair 1 Mar 12, 2024 10:14 pm Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want to salvage the shed as it's probably way cheaper than rebuilding. The shed also acts as a boundary fence, it's all fully approved from the 60s(?), isn't in the best shape, but overall seems fine. I will also replace the roof and roof structure if needed. It's a basic flat roof with only a few degree pitch with corrugated iron. I will also replace the current door with a roller door. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Perth Re: Brick garage/shed repair 2May 21, 2024 8:51 pm Turning this into my DIY shed makeover. I had a brickie fix the back wall up and it's rock solid now. I'm into ripping down the inside ceiling that was installed and replacing the roof. Pics to follow. I couldn't find some anticon blanket as all of the big green sheds were out. I settled on some sarking instead. The shed probably won't benefit much from from anticon blanket anyway. Perth Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3563 DIY, Home Maintenance & Repair Hi, recently a replacement rangehood was installed at my home and the installer cut holes through the double brick wall for the duct but left quite some damage to the… 0 2522 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5450 |
