Browse Forums Renovation + Home Improvement Re: roof structural repair 2Feb 21, 2024 9:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: roof structural repair 4Feb 21, 2024 9:05 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: roof structural repair 5Feb 21, 2024 9:23 pm building-expert For timber frame repair you are best to get a good framing carpenter Yes. I'm considering hiring a builder. They can handle everything for me, like the engineer design, building permit, etc... Re: roof structural repair 6Feb 22, 2024 7:08 am You have not specified the nature of timber frame repair. If you are merely repairing existing frame then you may be exempt from building permit. Why would you need engineering unless you are changing the structure? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: roof structural repair 7Feb 22, 2024 7:13 am because there are some cracks in the hip rafter and roof beams, so I think better to replace them. it is quite a large project, that's why I think building permit is required。 building-expert You have not specified the nature of timber frame repair. If you are merely repairing existing frame then you may be exempt from building permit. Why would you need engineering unless you are changing the structure? Re: roof structural repair 8Feb 22, 2024 8:08 am If you are in Victoria here are exemptions from building permit under Building Regulations
Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: roof structural repair 9Feb 22, 2024 8:27 pm building-expert If you are in Victoria here are exemptions from building permit under Building Regulations
Thanks for the information. Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32306 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47400 |
