Browse Forums Building A New House Re: Meter box placed in Facade 2Feb 10, 2024 2:44 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Meter box placed in Facade 3Feb 14, 2024 9:42 am chippy The meter box is a pretty simple box that really will never need anything done to it. You will also have a sub board in your garage. It's this sub board that may need upgrades if you get solar or add an air conditioner or the like. It's also this bub board that has the main switches, breakers and rcd's. Most modern homes would hardly ever open their meter box nowadays because all the important stuff is on the sub board. The meter box just gets painted the same colour as your wall and normally just blends in. Great thanks chippy. appreciate your time. Is this the standard of keeping the meterbox and sub board separately? bec i saw most of the homes have everything kept inside the meterbox in the side of the home. Re: Meter box placed in Facade 4Feb 14, 2024 1:46 pm Sara thy chippy The meter box is a pretty simple box that really will never need anything done to it. You will also have a sub board in your garage. It's this sub board that may need upgrades if you get solar or add an air conditioner or the like. It's also this bub board that has the main switches, breakers and rcd's. Most modern homes would hardly ever open their meter box nowadays because all the important stuff is on the sub board. The meter box just gets painted the same colour as your wall and normally just blends in. Great thanks chippy. appreciate your time. Is this the standard of keeping the meterbox and sub board separately? bec i saw most of the homes have everything kept inside the meterbox in the side of the home. I am adding my 2cents to this thread. Chippy is completely correct, you will have a sub-board inside your house. That can be the garage or a cupboard somewhere. We like to put them in a central point as we run all our cameras and NBN and the location depends on the design of the house. NBN only allows 2 bends in their conduit inside the home so sometimes this means the garage, or a cupboard in a discrete location. I personally like having all my switches in the kitchen so if lights go out on a rainy night or the toaster burns a piece of toast and trips a circuit you can easily reset the switch. It is also possible to just have your sub-board in the garage and your cameras and NBN in another location, just comes down to what works for you and your electrician. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Meter box placed in Facade 5Feb 14, 2024 7:14 pm Perhaps the most important point has been overlooked, Meter box and the "smart meters" inside should be as far away from the living, sleeping areas to reduce electromagnetic radiation. During my pre purchase inspections I have found many times, meter boxes as close as 300mm from bed heads. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Meter box placed in Facade 6Feb 15, 2024 2:03 pm building-expert Perhaps the most important point has been overlooked, Meter box and the "smart meters" inside should be as far away from the living, sleeping areas to reduce electromagnetic radiation. During my pre purchase inspections I have found many times, meter boxes as close as 300mm from bed heads. That is 100000000000% true! thanks for pointing this out. In a past life i was responsible for the redevelopment of the old ABC studios in Gore Hill Sydney and we had a big broadcasting tower which was still operational. So we had to get all the electromagnetic engineers out to assess that it was safe and they all agreed that meter boxes close to bedrooms was one of the most dangerous issues, especially for small children, followed closely by high voltage power lines. So that is a good point we can often forget. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Meter box placed in Facade 7Feb 19, 2024 10:31 am i spoke to my builder and he mentioned all switches, meter will be placed inside the meterbox which is located in the facade. HUB for NBN will be placed inside the garage. i asked the Solar guy to keep the inverter and battery provision inside the garage by running a conduit during framing stage. also asked my builder to add EV point inside garage. Bec the meterbox (have all the switches) is placed in facade and cannot fully recess as per my builder now, anything else i need to add/plan in advance to avoid any wires or pipes visibile in my facade. kindly advise. (note: my main living and bed room are placed in backside away from meterbox) Re: Meter box placed in Facade 8Feb 19, 2024 10:33 am Ashington Homes Sara thy chippy The meter box is a pretty simple box that really will never need anything done to it. You will also have a sub board in your garage. It's this sub board that may need upgrades if you get solar or add an air conditioner or the like. It's also this bub board that has the main switches, breakers and rcd's. Most modern homes would hardly ever open their meter box nowadays because all the important stuff is on the sub board. The meter box just gets painted the same colour as your wall and normally just blends in. Great thanks chippy. appreciate your time. Is this the standard of keeping the meterbox and sub board separately? bec i saw most of the homes have everything kept inside the meterbox in the side of the home. I am adding my 2cents to this thread. Chippy is completely correct, you will have a sub-board inside your house. That can be the garage or a cupboard somewhere. We like to put them in a central point as we run all our cameras and NBN and the location depends on the design of the house. NBN only allows 2 bends in their conduit inside the home so sometimes this means the garage, or a cupboard in a discrete location. I personally like having all my switches in the kitchen so if lights go out on a rainy night or the toaster burns a piece of toast and trips a circuit you can easily reset the switch. It is also possible to just have your sub-board in the garage and your cameras and NBN in another location, just comes down to what works for you and your electrician. thats really a great point. but my builder told the standard is to keep all the switches, meter inside the meterbox. any idea how much it will cost if i want to separate the swtiches and meter. Re: Meter box placed in Facade 9Feb 21, 2024 10:19 pm building-expert Perhaps the most important point has been overlooked, Meter box and the "smart meters" inside should be as far away from the living, sleeping areas to reduce electromagnetic radiation. During my pre purchase inspections I have found many times, meter boxes as close as 300mm from bed heads. Excellent contribution. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29427 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2986 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 8585 |
