Browse Forums Building Standards; Getting It Right! Re: Front door issues 3Jan 15, 2024 10:34 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Front door issues 6Jan 15, 2024 10:54 am yes, who checks that you are getting what is in the plans and specifications and to appropriate standards? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Front door issues 7Jan 15, 2024 12:26 pm Naively I wasn't aware of private building inspectors. I assumed incorrectly that because our builders had worked on many high end builds that the quality would be superior to some of the cheaper houses we had built in the past. Our building designer made a lot of mistakes as well and when we challenged the designer and builders on site, we were met with a united front from them, with no one taking ownership of the mistakes, and we ended up having to pay for mistakes to be fixed. Re: Front door issues 8Jan 15, 2024 12:35 pm ShaunD Naively I wasn't aware of private building inspectors. I assumed incorrectly that because our builders had worked on many high end builds that the quality would be superior to some of the cheaper houses we had built in the past. Our building designer made a lot of mistakes as well and when we challenged the designer and builders on site, we were met with a united front from them, with no one taking ownership of the mistakes, and we ended up having to pay for mistakes to be fixed. I recommend someone reviews your building contract and your build to see if there are other issues Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Front door issues 10Jan 15, 2024 1:25 pm How is the door supposed to keep the weather out? How will it contribute to the energy rating, leaking air as it does? The quality of manufacture is terrible. I notice the sill is set down into the slab, they may have made a calculation error in the overall door size to cause the gap. Can you post all the markings on the glass? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door issues 11Jan 15, 2024 6:34 pm The doors do not keep the weather out, we have rain and debris and bugs coming through the gap and when you open the doors after it's rained the brush seals on the bottom of the doors spread water across the floors. We're pretty gutted that we paid so much money and the quality has been awful. Also sad that the builder accepted it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Front door issues 12Jan 16, 2024 10:39 am The glass is compliant. The door is not. It's a builder's problem. Let me know how you go... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door issues 13Jan 31, 2024 12:39 pm AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances, i just looked at the 2017 version. Google search this term without quotations "nsw guide to standards and tolerances 2023 .pdf site:au" If your not in NSW, doesnt matter, all ther standards and tolerances are roughly the same for each state as they just restate whats in the NCC and referred Australian Standards. If you want to check the actual standard, you can do this for free if you go to readerroom (dot) standards (dot) org (dot) au Replace (dot) with and actual "." register, verify your mobile number then lookup AS2047 and read it. You can read three (standards) for free - then, wait for it, you have to wait 12 months before you can read three more - LOVE IT Stingy Bastards! You used to be able to read the standards for free up until 2018 when Standards,org and the National Libraries had an altercation of payment of Licensing fees. Let me just say, i back the National Library President who was batting for consumer access. Standards are way too expensive and restricting access to consumers is ridiculous for situations you just need to get the facts about something. Anyway, rant over, with the NSW standards and tolerances go to: Page 45 - Windows and Doors Section 9.1, 9.2 9 Windows and doors 9.1 Installation of external windows and doors Unless documented otherwise, external windows and doors are defective if they are not installed and flashed in accordance with the manufacturer’s installation instructions. 9.2 Weather-tightness of windows, doors, and window and door frames Window frame and door frame installations are defective if, due to the builder’s workmanship, they leak or cause unhealthy or dangerous conditions, loss of amenity for occupants, undue dampness or deterioration of building elements. Windows and doors are defective if, when closed, they allow the entry of water. Water entry through doors is not defective if they are not intended to prevent water entry. For example, vehicle access doors. Windows and doors are defective if they are not sealed in accordance with the requirements of the Building Code of Australia, where required. 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 3419 I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6614 12 5663 |
