Browse Forums General Discussion Re: Damp Internal Wall 2Jan 13, 2024 10:15 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Damp Internal Wall 3Jan 13, 2024 10:30 am Have had it confirmed it is not rising damp by specialist as it does not come up from the base of the wall and is dispersed at differing heights. Hoping plaster removal will now allow wall to dry out Re: Damp Internal Wall 4Jan 13, 2024 12:07 pm richbclare Have had it confirmed it is not rising damp by specialist as it does not come up from the base of the wall and is dispersed at differing heights. Hoping plaster removal will now allow wall to dry out You can use hairdryer Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21348 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8365 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 7192 |
