Browse Forums DIY, Home Maintenance & Repair 1 Jan 08, 2024 11:53 am Hey guys, real stressed out here. So I'm trying to create another living space in the garage, and I've put the frames up recently. With the torrential rain today in Melbourne, I went outside to have a look for leaks that could be coming through the roof, only to find puddles of water. Figured the source of this was from the dynabolts that I've drilled coming from the bottom (correct me if I'm wrong), as I've never had this problem until the frames went up. The concrete must have been fairly shallow, and I possibly drilled all the way through? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm thinking I have to take the frames out and repairs those holes as #1 priority... but after that i'm not sure how I would fix the frame into the concrete without this repeating. Will I need to waterproof the whole floor? Epoxy? I have no bloody clue. Can anyone help with a solution? Thanks so much for reading and hoping for some good input! Re: Leak through concrete after putting frames up 3Jan 09, 2024 4:35 am If that water was under the slab then you are, and were going to have huge moisture problems regardless. I would think it's got in somewhere else otherwise you may have to rethink your plans of turning it into a habitable room. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leak through concrete after putting frames up 4Jan 09, 2024 2:15 pm Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 12189 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 21094 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5716 |
