Browse Forums Eco Living Re: Rainwater tank issues 21Jul 16, 2020 9:41 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 23Jan 08, 2024 10:31 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 30Jan 08, 2024 5:00 pm Thanks for the photos. Your first two photos show a 'dry' system pipe that discharges into the meshed basket at the top of the tank. This downpipe should not be overflowing. You have said that two downpipes overflow from the top of the downpipes but the downpipes sit underneath leaf diverters. Do they overflow from the top of the downpipe under each leaf diverter or from the leaf diverters? The leaf diverter shown will often have a large aperture outer mesh that lets a lot of debris pass through that then clogs the finer mosquito proof inner mesh. Do your leaf diverters have the large aperture outer mesh and if so, have you been able to check the inner mesh for clogging? If the outer mesh is mosquito proof (less than 1mm apertures), you should still check to see whether there is also an inner fine mesh. The tank is badly sited. It should have been positioned with the leaf diverter at the end of the tank and a very short pipe plumbed directly from the leaf diverter to the meshed basket inlet at the left end. This would have allowed easy access to the leaf diverter for maintenance. Which direction does the house wall at the tank face? I know it isn't south! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 31Jan 11, 2024 9:58 am Waiting..... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Information asked for is required before a full answer can be given. There are also other design issues that the owner is most probably not aware of. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31468 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19881 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8663 |
