Browse Forums Building Standards; Getting It Right! Re: Electrical - Sub distribution box/lighting automation 2Dec 08, 2023 9:31 pm Krizzy82 1)Do I need an earthing rod for the Sub panel? If so what guage earth is sufficient? 2)The feeder cable from the mains is 6mm. I presume that should be more than enough as most circuts are LEDs.? 3) My mains switchboard would like to add an additional x2 Power circuts, plus the submain breaker but it looks like my SB is full. Will I have to upgrade my switchboard ? 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it out 3. no you can just swap out the old RCD and seperate MCBs to combination RCBOs so each group of 4 modules can go down to 2. Your sparky should sort all this for you I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2984 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9328 |
