Browse Forums General Discussion Re: Narrow block design with 2 car space 2Dec 07, 2023 3:14 pm Joda Hi We are doing a KDR. Due to narrow block (10.5m) CDC/council will not allow double garage. We would like space for 2 cars in the future. We have come up with this design which has a single garage and adjacent car space (carport style though technically not a car port). The garage is on the right side to align with the current driveway (it is unlikely that we can extend the driveway either to line up with the carport). Keen to get your thoughts on this and if it would work practically. Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ will the carport or the garage have room above? if not, the carport could be made to feel like a courtyard with some transluscent roofing but i would be inclined to have the carport against the side fence and the garage in te middle with internal garage access door through the front entry.. but difficult to be specific without upstairs plans and readable dimensions and i will attempt some ideas but can i suggest that you place scale sized furniture in all your rooms to be confident about available space eg how will you furnish the lounge with the door opening from your garage? Re: Narrow block design with 2 car space 3Dec 07, 2023 5:33 pm Thanks for your feedback, especially about the garage door to living room. Yes there would be a room above the ‘carport’. We would swap the garage and car port around but I believe we have to have a min distance between our driveway and the neighbours so have to leave the garage where it is. Re: Narrow block design with 2 car space 4Dec 08, 2023 12:47 pm dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture and some other ideas but something like this could work better for the carport, garage and entry and gives more comofratble options for living and direct access from carport and garage Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6788 You could be looking at anywhere between $400,000 to $800,000 depending on so many variables including: 1. Site conditions - what material is being excavated 2.… 1 2135 |
