Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 941Mar 13, 2023 5:21 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 943Mar 14, 2023 5:46 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 946Mar 15, 2023 5:42 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 948May 14, 2023 9:26 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 949May 14, 2023 9:27 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 951May 22, 2023 5:59 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 953May 23, 2023 6:33 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 954Aug 17, 2023 6:29 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 955Aug 19, 2023 11:37 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 957Oct 13, 2023 8:15 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 958Oct 13, 2023 11:34 am Michelle whatnext Morning. :) Please read below..... Hi michelle, I asked this in a different thread but wondered if you might also be able to help! I am looking to direct stick 14mm engineered blackbutt on top of an existing hardwood jarrah floor in a 30sqm lounge room. The existing timber is very solid and pretty flat already however we will have the polish sanded off and some minor high spots grinded down to ensure it’s properly flat. While we’d prefer to run the flooring in the same direction we will go perpendicular as for height reasons we can’t add a plywood base. I have checked the manufacturers installation guides and this is the approach they recommend. One thing I just can’t get a straight answer on is whether a moisture barrier or any other layer is needed between the old timber and new engineered board? Does anyone know? You glue it straight down, when gluing the underlay is not required. However, I thought you couldn't glue to a sub structure with movement, you might want to check that. Ring the maker of the flooring to find out, go straight to the source Or just glue it straight down with nothing in between? Ideally I don’t want to add an underlay as it will create some height issues. The same engineered flooring is being installed (direct stick as well) in rest of the house but straight onto the concrete slab. A moisture barrier is being used here (no underlay). YES, but it referred to as an underlay. Due to some issues with the slab heights from past renos (previous owners), the above approach actually results in the new floor being the same level throughout the house. I am also trying to ensure the feeling under foot is as close as possible between the room with the hardwood subfloor and rest of the house with concrete subfloor. My hope is direct sticking with nothing in between will help achieve this. Any advice appreciated! Good luck Moisture barrier and underlay are 2 different things. An underlay can act as a moisture barrier but for direct stick you paint on a moisture barrier that doesn't act as an underlay Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: I work in flooring - do you have a flooring question? 959Oct 15, 2023 12:38 pm I’ve got a bloody weird question Has anyone noticed excessive sock wear with hybrid? I wear socks around the house most of the time. We moved into a new build at the end of last year, since then I’ve been through 20 odd pears of socks. Get holes on the outside edge next to little toe. Different shoes, heaps of different brands and styles. Only thing I can think off is the flooring. Before I’ve lived with timber and Lino, this seems to have more grip and my foot slides inside the the sock but the sock grips the floor? I dunno, Tis very strange! I promise I’m not a total lunatic! Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41370 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11126 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5037 |
