Browse Forums General Discussion Re: Ramping Carpet Up To Bathroom Level 4Aug 02, 2023 2:36 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Ramping Carpet Up To Bathroom Level 5Aug 02, 2023 12:58 pm Our House Build strannik Get them to ramp down the tile to the carpet level Not sure they can do that, particularly given they use 40mm angles to contain the screed, waterproofing and tiling. Furthermore the tiles need to have falls to drainage points (for water to run away from the carpet as opposed to down onto the carpet). Thanks anyway. they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo your tiling ramp or no ramp. isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18296 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47577 Move your linen into laundry and access laundry from your present linen space 1 8485 |
