Browse Forums Building A New House Re: Hebel PowerFloor vs Traditional Timber Floors 3Aug 25, 2022 2:40 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 4Aug 26, 2022 12:56 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 8Jul 18, 2023 1:10 pm Hello_world To dig this thread up again "In my duplex I used red tongue and then yellow tongue and that gives a really firm feeling as well." Are you saying you installed the hebel floor, then red tongue then a further layer of yellow tongue? Hello_world In the duplex I used a layer of red tongue and then a layer of yellow tongue, no Hebel. In a number of homes we are currently building we have used a layer of Hebel and then either yellow tongue or red tongue over the top. My own home I used Hebel & yellowtongue and then acoustic insulation in between the floor joists and with that combo you cant hear the kids jumping off beds, Works a treat! Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 9Jul 18, 2023 1:38 pm I see in another of your posts you say lay the joists at 300mm (the csr tech info says 300, 430 or 600mm), but with red or yellow tongue, this would help distribute the loads on the hebel quite significantly (like furniture or people walking on) Do you still do 300mm with red or yellow tongue or do u widen it up to 430mm (reason i ask is insulation seems to come in 430 or 500mm widths not 300mm) Main diff between red and yellow tongue is one is 19mm other is 22mm?, or is there something more which makes red tongue better? What kind of additional per sqrm cost is laying red tongue over the hebel when your charge a customer for it? Re: Hebel PowerFloor vs Traditional Timber Floors 10Jul 18, 2023 1:43 pm The distance between joists is usually defined by the structural engineering and takes into consideration joist spans, it is not what the builder has a lot of control over. They would need to comply with 150 kPa minimum for distributed loads (people, furniture), but if you add Hebel and extra layer of board, you should be talking about 200 kPa+. Re: Hebel PowerFloor vs Traditional Timber Floors 11Jul 18, 2023 2:11 pm Hello_world I see in another of your posts you say lay the joists at 300mm (the csr tech info says 300, 430 or 600mm), but with red or yellow tongue, this would help distribute the loads on the hebel quite significantly (like furniture or people walking on) Do you still do 300mm with red or yellow tongue or do u widen it up to 430mm (reason i ask is insulation seems to come in 430 or 500mm widths not 300mm) Main diff between red and yellow tongue is one is 19mm other is 22mm?, or is there something more which makes red tongue better? What kind of additional per sqrm cost is laying red tongue over the hebel when your charge a customer for it? When we are using Hebel we like to put the joists closer together to minimise deflection as Hebel is brittle and any movement causes cracks. With particle board we can go up to 600mm and it doesnt make much of a difference. Insulation is then cut to size by the installers so this is not a consideration. Red v yellow doesnt make a hug difference. It really depends what our supplier sends us. Red is a lot more expensive though. I have to check but I think we charge around $40-50/sqm for the 2nd layer of yellowtongue where as Hebel is around $120/sqm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 12Jul 18, 2023 2:16 pm Putting particle board over and widening up the spacing would save some joist installation cost but? So the true additional cost would 40 - 50$ sqrm offset by a reducion in joists and installation Re: Hebel PowerFloor vs Traditional Timber Floors 13Jul 18, 2023 2:17 pm Seems that Hebel might require 2x more, this should be a significant cost increase.
Hello_world do you want to check XCEM? They should be okay/working well with wider joist space Re: Hebel PowerFloor vs Traditional Timber Floors 14Jul 18, 2023 2:18 pm Hello_world Putting particle board over and widening up the spacing would save some joist installation cost but? So the true additional cost would 40 - 50$ sqrm offset by a reducion in joists and installation Its hard to say as the engineer will specify the joist spacings so it's not as simple as just widening them from 450-600mm as joist spacings depend on a number of factors with the design such as loads and spans etc Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 15Jul 18, 2023 2:22 pm alexp79 Seems that Hebel might require 2x more, this should be a significant cost increase. Hello_world do you want to check XCEM? They should be okay/working well with wider joist space Why would people go for hebel if XCEM flooring is superior to hebel - according to the XCEM advertising material? Re: Hebel PowerFloor vs Traditional Timber Floors 16Jul 18, 2023 2:25 pm Hello_world alexp79 Seems that Hebel might require 2x more, this should be a significant cost increase. Hello_world do you want to check XCEM? They should be okay/working well with wider joist space Why would people go for hebel if XCEM flooring is superior to hebel - according to the XCEM advertising material? XCEM is quite new, they have just released this flooring less than a year ago or so. Hebel is CSR which invested obviously much more money into marketing and brand awareness for ages. Re: Hebel PowerFloor vs Traditional Timber Floors 17Mar 27, 2024 5:35 am I used Hebel powerfloor on the second storey of one side( the one I live in) the other side yellow tongue.. sealed it and direct stuck 19mm engineered flooring.. cost almost 10k supply and install the Hebel…it’s absolute rubbish.. the noise transfer downstairs is terrible to the point when sitting downstairs you can hear the cable from a phone charger hitting the floor when being in plugged. When I made a comment on socials they sent two reps out who said “that is noisy”.. it’s because you direct stuck it and didn’t use underlay. Then further to that they said look at our site for laying timber floating floor it needs underlay and for a full effect it relies on the underlay, insulation, resilient mounts and 13mm plasterboard to the ceiling for it to be truly effective.$10000 for a product that’s noisier than 19mm yellow tongue. Re: Hebel PowerFloor vs Traditional Timber Floors 18Mar 27, 2024 5:56 am 9348 I used Hebel powerfloor on the second storey of one side( the one I live in) the other side yellow tongue.. sealed it and direct stuck 19mm engineered flooring.. cost almost 10k supply and install the Hebel…it’s absolute rubbish.. the noise transfer downstairs is terrible to the point when sitting downstairs you can hear the cable from a phone charger hitting the floor when being in plugged. When I made a comment on socials they sent two reps out who said “that is noisy”.. it’s because you direct stuck it and didn’t use underlay. Then further to that they said look at our site for laying timber floating floor it needs underlay and for a full effect it relies on the underlay, insulation, resilient mounts and 13mm plasterboard to the ceiling for it to be truly effective.$10000 for a product that’s noisier than 19mm yellow tongue. It's the same as concrete floors in apartments and why strata rules are so strict about using acoustic underlays. Also I would never use Hebel on it's own as a flooring, we always put yellowtongue over the top to protect it and the result of the two in combination is brilliant. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel PowerFloor vs Traditional Timber Floors 19Mar 27, 2024 6:08 am Do you ever just use yellow tongue by it’s self, or do you double that up aswell or do you only use powerfloor? I think as a general buyer of the product power floor is advertised as an alternative to yellow tongue, you shouldn’t have to then fit 19 mm timber plus underlay plus a floor covering to benefit or if you do it should be advertised.. as stated in this thread people are unaware you need to do that Re: Hebel PowerFloor vs Traditional Timber Floors 20Mar 27, 2024 12:01 pm We used Hebel Powerfloor in our double storey new build. We didn't put any yellow tongue on top - I would have if this was offered by the builder at the time but it wasn't. On the upper floor, we have a mix of carpet (with good underlay) in the bedrooms and a good laminate with built in layer of underlay in the sitting area and hallway. Laminate is installed as floating rather than direct stick. We also had insulation installed in the downstairs ceiling between floors. After living in the house for 5-6 months, we notice very little noise transfer to the downstairs. Only time we hear any significant sound is if the kids jump down from their beds. traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4533 This is 100% true. You can not hang anything on steel frames. very frustrating 8 9665 1 6802 |
