The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give yourself the best chance to a successful project.
Step 1 – Planning and Design
Before we get into the two ways in which to go about the planning and design step the most critical attitude you must have is by ‘Having the end in mind’. Understand as best as practical what it will look like and how it will function. Now to best achieve this is to simply crawl the internet for inspiration, ideas, finishes, completed projects that are somewhat how’d you’d like to finish off your project. I always recommend using a pinterest board here to collate your ideas. This will help express yourself to suppliers, trades and your partner so they get an understanding of your crazy ideas.
After you have your inspiration there are two ways you can take the first step. Hint: First option is ideal 😊
1. Engage or seek advice from a professional who has undertaken the type of project you intend to carry out. This is a good approach as you will have the advantage of their network of trades and an understanding of all the issues you will face with your specific project. They will also be able to list out a step by step process on how to go about the project and be able to lend an ear as you progress through the construction steps.
2. Crawl the internet and find step by step processes for the specific project you have at hand and start writing them out. This process is very difficult as there are many ways to execute the same project and they can all lead to an adequate result. You wont have anyone to oversee what you are doing during the construction step so you will need to heavily rely on the trades you engage for some direction during this process.
Whichever method you intend to proceed with you need to have, in place an idea of what you want to achieve and a step by step process of how to achieve it. This will include the fixtures, finishes and trades needed. A critical element to end with during this step will be the lead times on goods and services from ordering to arrival onsite. Having a list of these leads time will help you priortise how you order/engage the goods and services for the job ahead.
Step 2 – Construction
We are getting into the detailed component of how to DIY the right way, basically with any project you can break them down into 4 construction phases.
1. Demolition
2. Structure and Services
3. Lock up
4. Finishing
Depending on the project you may not need all the phases so you can simply disregard what is not necessary, for example a kitchen renovation may only need some detail demo, removing some joinery and finishing which would include new cabinets, fixtures and splashback. What I’ve done here is explain what the phases are and give you the Do’s for each construction phase, giving you some items to consider and the best chance at a successful DIY project.
Construction Phase 1 – Demolition
Before we start a project we usually have some demolition works in place that are required to be undertaken to prepare for the plan ahead. Demo is a great scope of works to be undertaken if you are doing it yourself because it can be a big cost saving exercise.
Do’s –
1. Install temporary protection or hoarding for the project ahead.
2. Get a qualified plumber and electrician in first to disconnect the services and make safe the area before any demo work start. They will also need to indicate what is still live after they have gone to avoid issues during the demo process.
3. Have the area inspected and tested for asbestos and removed accordingly.
4. Undertake the detailed demolition of the project, this includes removing everything other than the live services and any structural components to the home. This would include plaster, insulation, tiles, doors, windows, etc.
5. Have the structural elements of the building be removed by someone with building knowledge to mitigate any unwanted structural failure. This includes brickwork, timber framing, etc.
6. Be methodical, demo is the act of working backwards, removing everything piece by piece as it was installed and not smashing walls with a sledge hammer, that’s the worst approach.
7. Sweep, vacuum, clear out the entire work space ready for the second phase of construction.
Construction Phase 2 – Structure and Services
Now that we have our work area stripped back we will start the process of rebuilding to the design/plan you have in place. This includes modifications or new walls, ceilings and services. This is going to set up the foundation to the lock up and finishing of the job. By the end of this stage you will know detailed locations of your fixtures, finishes, cabinets, doorways, etc. Everything built in place ready to plaster or clad.
Do’s –
1. Have all your fixtures and finishes onsite or if not, the detailed specification sheet for them available. This will be needed for yourself and the service trades to understand the end result. This includes such things as wall finishes, floor finishes, sinks, architraves, handles, tap sets, etc. They will need this for their set out in the wall cavity and location of finishes are correct.
2. Engage a carpenter or builder to undertake the structural changes necessary to complete the scope. You can always lend a hand to save on costs here but it is not recommended to undertake the entire scope if you have no idea what you’re doing.
3. Services trades come in and complete their scope of works. That may be, modifications, relocations or new installs. You will need to engage the specific service trade to undertake these works, you will need certificates to say it was done correctly and compliant. Attempting these trades yourself will lead to future problems and cause you unnecessary drama. If you’d like to save money in these areas you may be able to lend a hand with some labour but there isn’t a lot that can be done. So deal with it.
Construction Phase 3 – Lock up
The lock up phase is simply when you close in any external elements of the project, say you’re changing some claddings, windows, etc. For a DIY project this will usually be a small component as extensions and new builds usually involve a builder to manage the project.
Do’s –
1. Have your window and door order well in advance, usually you want this done after the demolition phase once you know the locations/dimensions of what you’re intending to build or modify. This is due to the lead times faced with fabrication.
2. Unless you’re rendering a wall, don’t attempt to lay brickwork and think it will look sexy. Even an experienced bricklayer will struggle to match in the changes made so I recommend outsourcing this job if at all possible.
3. Ensure the cladding system you install is done by the installation guide it comes with, there are many products to use and usually a small number of ways to install it. Ensure you do it the right way. This will ensure the cladding is water tight and achieves what it’s designed to do.
4. If any sections of the cladding need a sealant to keep the home water tight, you will spend top dollar on that external sealant. If it needs to be paintable and flexible ensure you get the correct product, getting the cheap, half arsed option will lead to unwanted dramas and isn’t worth the trouble.
Construction Phase 4 – Finishing
The finishing phase is the most detailed and involves the most work of any project. Now this is where as a DIYer you will be in your element, learning the bit and pieces you have picked up from videos online, friends or by having a read hot go. The list of items below will be broad to try accommodate all DIY projects that you may occur.
Do’s –
1. Engage services trades to ensure you meet compliance and get certification for the install. Also engage trades that you do not want to attempt if you know your limitations.
2. Communication with your trades is critical throughout the entire process. Get a detailed quote/scope of works, ask them their lead time? When they need to come in during construction? What they need from you? What issues they may face? What they are going to do and what they not going to do? This will give you a good understanding where the holes are with the plan and where you need to provide feedback for the other trades and for yourself when executing the works. Example of this would be the Tiler who wants the cabinets and the benchtop in before they tile the splashback. Plumber will come in after both the benchtop and splashback are installed to fit off his fixtures. Now you can silicone the splashback and joinery after the fixtures are installed. Get clear with the trades where they slot in during the construction process.
3. Every product has an installation guide, so when doing the works yourself you need to look up the tech data, specifications, installation guide for the product and install it in accordance with the manufacturer’s instructions. This will ensure its done correctly and not void any warranty.
4. Doing it yourself will not always save you money. Attempting a difficult and critical task may not be worth the effort. If you fail and need it to be redone by a tradesman it will cost you more time and more money. I know for myself as a carpenter/builder this would be the plastering, this is one trade I could never get right and it has burned me too many times. I just pay the man now and do what I can elsewhere to save a dollar.
5. Waterproofing should be outsourced and you should get a certificate to say that it was done in accordance with the relevant standard. This will be helpful in the future if anyone was to ask if it was undertaken and mitigate the risk of you doing it incorrectly. This is critical for not only internal wet areas but also balconies, planter boxes and areas exposed to the external elements.
6. Be patience and don’t expect to ‘The Block’ timeframes. You are not skilled, you will be slow, don’t rush the process and be patience or you will miss a step which can result in disaster.
That’s it! How Easy!
So let’s recap on how to DIY the right way…
RECAP - Step 1 – Planning and Design
Get your inspiration together and understand WHAT you are going to do and HOW you are going to go about it. Have a specialist come out and give you a set by set process on what you’ll be in for and get their network and support during the construction. Or go online and seek out the process for the type of project you’re intending to execute and come up with you plan of attack
RECAP - Step 2 – Construction Phase
Demolition
1. Service trades first to make safe.
2. Builder/carpenter to deal with structural situations
3. Suspected asbestos to be tested and removed if needed
4. Temporary protection put in place
5. Demo is the opposite of building. It’s piece by piece not a sledge hammer through the wall.
1. Service trades used for certification and compliance.
2. Builder/Carpenter used for structural changes/works.
3. Have the actual fixtures and materials onsite or at least the detailed specifications of what is to be used on hand for all trades.
Lock Up
1. Don’t lay brickwork
2. Follow the installation instructions
3. Don’t get cheap external sealants
Finshes
2. Communication is critical. Scope of the trades is very clear. You will be the voice between all the trades to ensure it runs smoothly.
3. Follow the installation instructions.
4. Outsourcing something too hard will save you money.
5. Waterproofer to give you a certificate of compliance.
6. Be patience, take you time, you are inexperienced it will take to much longer than you may think. Rushing it may result in mistakes you cannot fix.
DIY projects like all projects can be very complex. This approach to doing it yourself should at least be understood to help mitigate the common issues people face. We don’t want you to end up with an unsafe, ugly, problematic and non-compliant project that can land you in hot water if the building authorities pick up wind of your sub par work.
Good Luck!
Myles
