Browse Forums Landscape & Garden Design Re: Dry Well in the backyard 2Jun 15, 2023 1:07 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 5Jun 15, 2023 10:21 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 6Jun 18, 2023 8:10 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, I did the pit checkup and noticed that 3 pipes. two terracotta and one small pipe that goes out to the ground. When do check the top pipe with the cam its goes towards the house for 3-4M but no water coming. The bottom small pipe goes only 0.5M and the third pipe again 1M and shows some roots blocking the pipe. I have emptied 2-3 times for the last 2 days and still filling the tank. What do i do now? Re: Dry Well in the backyard 7Jun 19, 2023 6:34 am The lower terracotta pipe indicates that it is a DIY silt pit with a blocked bottom pipe and a top inflow pipe that is no longer connected for whatever reason. The constant filling will be water table infiltration if the top pipe no longer carries water and the 'well' allows water to seep in but not fast enough to maintain supply to even a small pump. I would be concerned with the possibility that you have a high water table and can only suggest that you monitor the top pipe for any inflow when it rains as the surrounding high water level may be localised if there is inflow. The result of the monitoring will decide your next step. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 8Jun 19, 2023 5:12 pm SaveH2O The lower terracotta pipe indicates that it is a DIY silt pit with a blocked bottom pipe and a top inflow pipe that is no longer connected for whatever reason. The constant filling will be water table infiltration if the top pipe no longer carries water and the 'well' allows water to seep in but not fast enough to maintain supply to even a small pump. I would be concerned with the possibility that you have a high water table and can only suggest that you monitor the top pipe for any inflow when it rains as the surrounding high water level may be localised if there is inflow. The result of the monitoring will decide your next step. Thanks, So what is the third pipe do? Re: Dry Well in the backyard 9Jun 20, 2023 10:22 am I have no idea! I can only surmise as I have done without being on site and doing some excavation but the three pipes tend to rule out it being a small dedicated well. It's an interesting topic and all I can say is that the answers may require some digging to determine the original purpose of the 3 pipes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 10Jun 21, 2023 10:27 am SaveH2O I have no idea! I can only surmise as I have done without being on site and doing some excavation but the three pipes tend to rule out it being a small dedicated well. It's an interesting topic and all I can say is that the answers may require some digging to determine the original purpose of the 3 pipes. I thought this may be designed to soak well. so the third pipe just goes to the ground. Re: Dry Well in the backyard 11Jun 21, 2023 12:09 pm It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full and it appears that it never empties. What is your soil type? Soak wells need sandy soils. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2527 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 4141 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25380 |
