Browse Forums Owner Builder Forum Re: Concreter in Sydney area 9Apr 30, 2023 10:58 am qrius alexp79 If he proves to be good, I will be able to recommend him to you. Does 'no reply', mean no recommendation because he wasn't good ? I'm wondering about the concreters too, in Sydney. Primarily for a ~3m wide driveway, for about 60+ metres, and some more for extension of this driveway, into a car turning / parking bay (maybe 15m x 5m area) If it helps, I ended up using kookaburra concrete. Speak to owner Brad, good guy (was willing to roll with exact scope I wanted). Re: Concreter in Sydney area 11May 01, 2023 12:33 am arab3455 If it helps, I ended up using kookaburra concrete. Speak to owner Brad, good guy (was willing to roll with exact scope I wanted). Thank you for recommending. Also, do you have any ideas of costs, as in, what's a ballpark estimate for a total area of 250 sqm for driveway access ? Re: Concreter in Sydney area 12May 01, 2023 9:42 am Just checked the list of the forum's concreting pros and found it strange that there are numerous from Melbourne but few from anywhere else. You could take a walk (or a bike ride) around your local area one Sunday to look for new driveways and do some door knocking. Most persons are forthcoming.. Ask then check how long any concreter you talk to has been in business and addresses of their most recent work. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 12186 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17605 Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12898 |
