Browse Forums Building Standards; Getting It Right! Re: Frame sitting off slab 22Nov 16, 2022 7:51 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Frame sitting off slab 23Nov 17, 2022 8:24 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Frame sitting off slab 26Dec 20, 2022 10:12 am CTSB It's very likely that overhang voids the support required for the framing and thus voids the engineering the frames were supplied with. This is your angle, not the statutory one. Find out who the supplier of the framing is, as they are the ones with the PI insurance attached to it's structural integrity and design. They didn't design it and comp it to overhang a slab by 35mm... Good points that logically cannot be argued against but the BCA was changed a couple of years ago to delete manufacturer's recommendations. Not sure whether the very good points you make would stand but it's certainly worth a try. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16270 This is 100% true. You can not hang anything on steel frames. very frustrating 8 10398 This is the best I have, as it is plastered internally now. I should add there is a steel post in the corner of the room between the window and the glass sliding door,… 3 1095 |
