Browse Forums Heating, Cooling & Insulation Re: Help removing ceiling vents 8Oct 16, 2022 11:21 am I'm glad I could help you with this! Yeah it's such a frustrating design that doesn't really favour ease of later adjustments. But at least you were able to remove it in the end. Re: Help removing ceiling vents 11Dec 29, 2023 3:21 pm These round ones are much easier! They are attached to the ceiling by three spring loaded clamps, spaced evenly around the circle. To remove, find a good grip by slipping your fingers around the vent grills, and GENTLY pull down. You'll start to feel the unit come away from the ceiling. Keep going, and I stress again GENTLY. Be careful not to pull too hard as you run the risk of ripping through the ceiling plasterboard. At a certain point, the three clamps will release and you can then pull the unit out completely. Depending on the age of the unit, the clips might feel a little stuck. Just keep slowly pulling and eventually the downward force should release the clamps. To put it back in, make sure the clamps a primed in the released position. When you raise the unit back into position, the clamps will make contact with the ceiling and the spring loaded mechanism will snap them shut into place. Hope this helps! Re: Help removing ceiling vents 12Dec 30, 2023 7:35 pm Hi BC, Sounds good, did a round one today, came out a treat. Re: Help removing ceiling vents 13Jan 01, 2024 10:10 am Trueseadog Hi BC, Sounds good, did a round one today, came out a treat. Glad I could help! 😁 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 16683 Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 4510 Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1940 |
