Browse Forums Kitchen Corner Re: Edging for absolute matte different colour 2Jun 24, 2022 1:12 pm Rizzo The edging should be very similar in colour. Polar white is what I would call the most stark white that Laminex do so if they have used polar white board then they could not have got a more stark white matte edging. You can get absolute matte in polar white and white. Unless they used white board and polar white edging. The edging is obviously a different material (ABS vs HPL) so there is a slight difference in the product but overall it should look very similar. The other thing is just being at 90⁰ to each other can make particularly whites look a different shade but when layed directly on top of each other in the same light they are the same. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Edging for absolute matte different colour 3Jun 24, 2022 1:30 pm chippy @Rizzo The edging should be very similar in colour. Polar white is what I would call the most stark white that Laminex do so if they have used polar white board then they could not have got a more stark white matte edging. You can get absolute matte in polar white and white. Unless they used white board and polar white edging. The edging is obviously a different material (ABS vs HPL) so there is a slight difference in the product but overall it should look very similar. The other thing is just being at 90⁰ to each other can make particularly whites look a different shade but when layed directly on top of each other in the same light they are the same. Thanks chippy. They are going to come and take a look so will have to see what they say but if we had of known this was the result, I wouldn’t of done it. Don’t know if you can see in these pics the difference. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Edging for absolute matte different colour 5Jun 24, 2022 2:00 pm Pictures of melamines and laminates are very hard to fully capture colour variations. It does seem to be different though. It may be that the board is actually white rather than polar white and they have used polar white edging. Do you have a sample of the polar white absolute matte? "Polar white" is stark cool white while "White" is a warm white. You will see a difference between them side by side immediately. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Edging for absolute matte different colour 6Jun 24, 2022 2:05 pm The other possibility is they have used a white edging or board from another supplier (Polytec) thinking that it was the same but is infact very slightly different. There are so many different whites from suppliers. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Edging for absolute matte different colour 7Jun 24, 2022 3:00 pm chippy Pictures of melamines and laminates are very hard to fully capture colour variations. It does seem to be different though. It may be that the board is actually white rather than polar white and they have used polar white edging. Do you have a sample of the polar white absolute matte? "Polar white" is stark cool white while "White" is a warm white. You will see a difference between them side by side immediately. Yes and it matches the fronts of the cabinets whereas the edging matches the inside. What we found from our samples is that the absolute matte polar white is actually a little different to the regular polar white, so I’m wondering if they have just used polar white edging not the absolute matte one if it’s different. yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5345 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6667 Hi All, This is our second home build and first time with a custom builder. They are small builder and have built some houses with good quality. They tender and color… 0 982 |
