Browse Forums Buying Land Re: Anything wrong with this land before I purchase? 4Mar 17, 2022 8:59 pm So I pieced together the plans from neighboring lots, and it appears the contour lines are actually 0.25m apart. See updated markups below. Essentially 4 contour lines are: - Front of house (street): 105.25m - Garage: 105.00m - Near middle of lot: 104.75m - Rear (behind stormwater drainage): 104.50m Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Based on the above, is it fair to assume the slope is about of 0.5 - 0.75m (decline)? Any idea what this might translate in terms of added site cost? Is it likely a couple thousand dollars, or tens of thousands? Jason526 The Atlantis house you want to build from Fowler says min. lot width 9.67m. You have an easement G (0.9m) on your side which is for maintenance. Just check if you will be allowed to build over this easement. Otherwise you'd only have 9.1m wide to build. The width of the build is actually 8.27m. Not sure where they got the 9.67m from, but I also checked with one of their sales consultants and was provided with a preliminary sitting, in which the width of the build was also 8.27m. I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 37355 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18633 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16675 |
