Browse Forums Lighting + Lighting Design Re: Relocating thermostat above light switch 4Aug 28, 2021 9:30 am basKT_case Is that something a stud finder with live wire detection will tell me? Should do, but turn the power off anyway when you are drilling/cutting in that area. basKT_case I am interested in a Nest Thermostat to combine both heating and cooling controllers into one device. Though i understand i will lose the variable fan control of the evap cooler. You should do significant research on that. Nest Thermostats are not available in Australia and not official supported for a good reason. While many of us have made them work, you’ll need to determine compatibility with your Brivis system. It may be that you will need to install an intermediate relay system. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 2001 3 3246 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12906 |
