Browse Forums Outdoor Living Re: Composite decking choices 7Jul 21, 2021 10:50 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Composite decking choices 9Jul 22, 2021 7:50 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Composite decking choices 11Jul 22, 2021 9:41 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Composite decking choices 12Jul 24, 2021 5:47 pm Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Composite decking choices 14Jul 25, 2021 2:29 am Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Composite decking choices 16Jul 25, 2021 5:08 pm I take it back, my partner says lengthwise it does expand in the heat. The gap pictured would be smaller in the summer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Composite decking choices 17Jul 25, 2021 7:09 pm All composite decking expands with heat. It's one of the main reasons they fix using brackets that allow this movement. It's also why they specify leaving 5mm between end joins so each board can expand without buckling. It doesn't matter what brand this will happen. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Composite decking choices 18Jul 26, 2021 3:06 pm Personally, we would have gone for Trex but we have a big decking area and it would have cost us almost double. Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Composite decking choices 20Oct 13, 2021 4:32 am Splashers Personally I have trex about 70sq/m of decking in various locations, shaded, full sun and around my fish pond and for 5 years i have had no issues on any part it is still flat as and no colour change or weathering as of yet. Simple clean with mild soapy water and a good brush with broom and rinse n its brand new again. I have done many installs and only like using Trex or Millboard but it is hard to justify the money for Millboard. New Tech is an upgrade from Ekodeck but its very similar as its made kinda the same product but a much better version than Ekodeck. Best advice is to either buy a length of each around 1 mtr if possible and just lay it in the area you are looking at and see how it bends in the sun without fixings, try cutting it and see the edges after cutting if they can be sanded or the plastic burrs up, Ekodeck burrs up and edge cuts are ugly. Hi This questionis not related to the topic but about the price you getcharged. Since you install composite deck, I would like to seek your advice. If the deck you built is 30 sqm, will you charge for 30 sqm or 33 sqm? My deck builder charged me & I am told it is for the matetial that was cut & threw away. His rate is $300 so 33 x $300 = $9900 $900 extra I paid is not only for material but include installation price too for 3 sqm he threw away. Is it normal? Can he really charge for that 3 sqm? Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13190 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 16249 Hi, Really struggling to find some consistency amongst Span Tables, can anyone help… 0 2867 |
