Browse Forums Flooring & Floor Covering Re: Is there a better solution to floor tiles? What do hospi 4Jun 27, 2021 7:50 am I recall it was used in school floors a lot. I just googled "what are hospital floors made of" and results say sheet vinyl. Flooring stores sell in planks but you should be able to get sheet vinyl done somewhere too. Re: Is there a better solution to floor tiles? What do hospi 5Jun 27, 2021 9:17 am Goxxo I recall it was used in school floors a lot. I just googled "what are hospital floors made of" and results say sheet vinyl. Flooring stores sell in planks but you should be able to get sheet vinyl done somewhere too. Thanks I’ll ask the local flooring store Re: Is there a better solution to floor tiles? What do hospi 6Jun 27, 2021 6:25 pm Hospitals use sheet vinyl that is glued down and all the joints and seams are welded. It makes for a very durable finish. Loose lay vinyl planks that are used in a domestic setting are also very durable. Some are designed to be layed on bare concrete but most manufacturers recommend using pressure sensitive glue that means the planks are lightly adhered to the floor but can be easily removed if a plank needs to be replaced. Then there are hybrid planks that clip together like floorboards but are made from vinyl. Plenty of options to consider Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Is there a better solution to floor tiles? What do hospi 7Jun 27, 2021 8:55 pm Thanks will check them out 👍 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3637 Sorry! I'm new to this forum and have made a mistake in my posting! I'm looking for a structural solution to a stand alone wooden pickets fence with no structural rail… 1 3428 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7864 |
