Browse Forums Outdoor Living 1 Jun 20, 2021 7:41 am Hi there, I am making floating eko decking (close to the ground) which is extending from my afresco and do I need geo fabric & crushed stone under the deck? If I do, should I put geo fabric or plastic weed mat under the crushed stone? Re: Geo fabric or plastic weed mat under deck? 2Jul 20, 2021 9:05 am Eko deck requires a certain air gap underneath as per warranty please check this before installing, mould can be an issue. Weed mat and 20mm bluestone/gravel is enough but the gravel needs to be approx 10cm to stop weeds n pests from nesting under. Personally i have never used weed mat or geo as when it gets wet it holds moisture which adds to the humidity underneath. Geo fabric is intended to stop dirt washing through it but allows water to seep through to drainage underneath it, its basically a filter. It is not a weed mat to lay on dirt to suppress weeds it will just hold the water if laid on ground. Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 3699 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6642 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5896 |
