Browse Forums Eco Living Re: Chemical tank use as water tank ? 4Apr 02, 2021 9:22 am Kaysin So recently I wanted to buy a water tank for my home so I can put it on my attic in case the water cut off. I found a guy from the internet marketplace and I bought a empty Square Tank 1000L , My question is can I use it for water storage use ? Yes you can but having a container that can hold 1,000 kg (1 ton) of water sitting in your attic is a different matter, something you should get professional advice about. How do you plan to move the container into the attic in any case? In Australia, you also have to consider the legality of any plumbing and only use a registered plumber licensed to do that class of work. Are you North American? Why not have an outside tank with water pumped via a filtration system to a smaller attic header tank? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Chemical tank use as water tank ? 5Apr 02, 2021 4:43 pm SaveH2O Kaysin So recently I wanted to buy a water tank for my home so I can put it on my attic in case the water cut off. I found a guy from the internet marketplace and I bought a empty Square Tank 1000L , My question is can I use it for water storage use ? Yes you can but having a container that can hold 1,000 kg (1 ton) of water sitting in your attic is a different matter, something you should get professional advice about. How do you plan to move the container into the attic in any case? In Australia, you also have to consider the legality of any plumbing and only use a registered plumber licensed to do that class of work. Are you North American? Why not have an outside tank with water pumped via a filtration system to a smaller attic header tank? Hello thank you for your answer Yes my attic floor is made of cement and under it has pillars supporting it ( am from Greece) Re: Chemical tank use as water tank ? 6Apr 02, 2021 4:43 pm Althom Is your attic engineered to take the weight of 1 tonne of water over a square metre of floor space? Hello thank you for your answer Yes my attic floor is made of cement and under it has pillars supporting it If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17848 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11182 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1871 |
