Will do. At least I now have a starting point ...
Browse Forums Pools & Spas Re: Sealing Pavers - Pool 39Feb 02, 2021 2:59 pm It is better to let Travertine breathe around a pool and i wouldnt seal them. They are a great natural stone that is really easy to maintain. Re: Sealing Pavers - Pool 40Mar 21, 2024 4:03 pm Hi 👋 Can you please help me. We want to instal Garonne limestone pavers around a pool. We have been told to pre seal them with the dip method. My question is, is this necessary if our pool is a magnesium pool? Can we get away with just a top sealer after instal? Thankyou Missed this and note sure how, sorry. The important thing I must ask first and foremost that has been missed in this thread is is the pool a salt water pool and what type of material are you sealing. If the product is a porous paver you must consider consolidating the stone to avoid salt attack. This help with the strength of the stone and avoid any delamination further down the track. Regardless, we believe it is important to seal around pool areas. Where possible use a good quality product by a reputable manufacturing company. Penetrating sealers are better around pool areas as you don't have to worry about slip issues. They sit below the surface of the stone and should not change the colour of the stone. Two coat application for all sealers is recommended. With a life span of 3-5yrs in general. Any tips to watch for - the main one I recommend is just to have an eye for detail when sealing. If the area isn't cleaned down properly you will seal it with stains left behind. Don't use hydrochloric acid to clean with. Nasty stuff. Roller is good to apply. Low pressure spray better in my opinion. If you use a roller, medium nap roller is fine. Let me know if I can help further.[/quote] Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7417 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 6706 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 19955 |
