Browse Forums Kitchen Corner Re: Is 700mm too tall for a splashback window? 8Jan 30, 2020 6:33 pm lockmac I am working with my cabinet maker in trying to work out the most ideal size for a window for our walk in pantry. We have a 2700mm ceiling height and with an 1100mm tall overhead means we have an opening of around 680mm for the window. Does anybody have a similar height splashback that they can show some photos of what this looks like? I'm concerned that it will be too tall. The alternative is to get a 600mm window and just plaster above the window (so the overhead wouldn't butt against the window), but I think this might look worse than a taller window. 700 high is perfect. by chance i was visiting display homes the other day and came across one that was perfect. this measured approx 720mm If you're in a flood zone, not only are you dealing with the importation of fill and laying it down in 150 lifts to achieve compaction, you're going to have to consider… 4 5792 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8771 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5868 |
