Browse Forums Real Estate Re: Boundary between properties 3Sep 10, 2019 7:43 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Boundary between properties 8Sep 10, 2019 11:44 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Boundary between properties 11Sep 10, 2019 12:04 pm There is an electricity pit which may be just on or outside the boundary (and therefore on the nature strip which is council land. Re: Boundary between properties 12Sep 10, 2019 12:44 pm How unusual. Maybe the surveyor's idea of fun. I can't understand why they didn't go in a straight line. Might still be worth approaching council to see if there was a reason. The land is definitely theirs. Try approaching your neighbours and see what they say but I have a feeling they are going to ask you to change your retaining wall Re: Boundary between properties 13Sep 10, 2019 2:40 pm I would just put an angle on that part of the retaining wall and then continue to the boundary. Re: Boundary between properties 14Sep 10, 2019 3:05 pm bestspecials I would just put an angle on that part of the retaining wall and then continue to the boundary. Worst case that’s what we will have to do. I’m just hoping to find a solution that allows us to have a curved wall rather than a zigzag one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4139 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 17230 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17920 |
