Browse Forums Home Theatre & Automation Re: Duelling Z standards and power outlets 6May 10, 2018 1:04 pm arcadelt Ent Massively improved security as the lock has to be defeated from the inside rather than a simple turn the knob. Surely security has fail if they are already inside? So let’s make it easy if they force a back toilet window to walk your 65” screen tv out the front or back door? Neighbours tend to get suspicious if the see goods been removed by windows and not so much if by a normal door. Re: Duelling Z standards and power outlets 7May 10, 2018 1:06 pm Ent arcadelt Ent Massively improved security as the lock has to be defeated from the inside rather than a simple turn the knob. Surely security has fail if they are already inside? So let’s make it easy if they force a back toilet window to walk your 65” screen tv out the front or back door? Neighbours tend to get suspicious if the see goods been removed by windows and not so much if by a normal door. No, just walk it out your 65" wide window instead. Point is, one of your criteria is limiting your others. You have to figure out which criteria is more important. Re: Duelling Z standards and power outlets 8May 10, 2018 1:13 pm Ent So, do Zwave and Zigbee wired power outlets exists? Probably not in Australia as the market is too small; however, this site is probably not the best one to get such an answer, so you might want to consult one of the dedicated home automation websites/forums or one that is a bit more tech oriented (sorry homeone, but it’s about depth of knowledge). Re: Duelling Z standards and power outlets 9May 10, 2018 6:53 pm Actually these type of forums tend to better as you are more likely to get the warts and all approach than this is great. Home automation is growing and might wind up as common as the smart phone. Someone might have used the stylish Clipsal rang of momentary button push switches and wired in a controller behind it. The also appears to be no active smart home forums in Australia. On locks I would hazard to guess many would not be aware most locks can be bumped in about the same time it takes to open them with a key by someone with very little training. Get ready for the European style insurance lock, where to get insurance your locks need to be of a certain standard. Mean time around 1 in 68 homes a year are burgled. Yeap, once in a lifetime average but still a very traumatic event even if you have a good insurance company. Re: Duelling Z standards and power outlets 10May 10, 2018 7:24 pm Ent Home automation is growing and might wind up as common as the smart phone. Someone might have used the stylish Clipsal rang of momentary button push switches and wired in a controller behind it. IMHO, I think home automation is on the increase because of the internet of things, and most products in that category are for retrofit. Unfortunately traditional wired in automation is probably on the decline. Anyway, I'm now subscribed to your thread so we'll see what other responses you get. Re: Duelling Z standards and power outlets 11May 14, 2018 10:25 pm Sockitz appear to be an option, assuming their website actually works! The approach is sensible with you buying the power outlet and also been able to chose the communication module from either Zwave or Wifi. Gives capacity to help mitigate jumping the wrong way. They have a C USB charging version which would be handy for say a room set up as an office. As said they are a hard mob to get a response from. But their ideas are on the money. Brought another TP-Link switch for a difficult to reach power outlet controlling the heater in my office and second Google Assistant. Yeap, software challenges. Could not add new device so had to delete the TP-Link and reconnect to Google Home. Very handy little device if some what clunky in appearance. Power monitoring good as with a oil heater it is the cycle on time that governs power consumption so you get a good idea what it takes to heat a room. We are having a bathroom reddone. The builders are putting down two coats of waterproofing and then screed and then another coat of waterproofing. This is what I have been… 0 9980 I am trying to find lighting for kitchen, dining areas but looking online, I don’t know if there are specific details I should be looking at to make sure any lights I… 0 25555 |
